ECU extension cable - Defender Source
Old May 30th, 2011, 05:29 PM
Rugbier's Avatar
Rugbier
Gustavo
ECU extension cable
Scorpion Racing used to sell this, it was a male/female 36" cable that will allow you to place the ECU anywhere you want in the bulkhead.
Any idea where to obtain?
any qualified genius can make them?
NO SIGNATURE
Old May 30th, 2011, 08:48 PM
maleger
Marc-Andre Leger
ECU extention
I'm a certified Geek and own a geek pride tshirt... but not a genius. I would love to make myself one of these extentions, but have not yet been able to find the right connectors.
A source for the connectors to make the cables would make me happy !
------ Follow up post added May 30th, 2011 08:49 PM ------
Old May 30th, 2011, 09:49 PM
Grab a chunk of harness and the ecu from a disco at a junk yard. Should just be a matter of de-soldering the connector from the ecu board and soldering it up to the chunk of harness no?
No genius, but pretty geeky and proud of it.
Originally Posted by pendy
I'm here for the D's
Old May 30th, 2011, 10:03 PM
Rugbier's Avatar
Rugbier
Gustavo
There is a great chance of Hell freezing over before I could manage soldering computer type connectors
NO SIGNATURE
Old May 31st, 2011, 01:20 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Why bother with soldering, just splice in a section of cable. Crimp connect or solder, it's just time consuming, not difficult.
Tony
1984 110 "Smokey" (sold)
Old May 31st, 2011, 08:22 AM
The only difference is that you could just plug/unplug and leave the existing wiring intact and unchanged.
But yes it would be much easier to just splice in an extension piece from a disco.
Old May 31st, 2011, 10:09 AM
A 14cux genius I am not. But, wouldn't butt connector or soldering longer wire in change some of the resistence readings from say the temp sensors and tps ?
Old May 31st, 2011, 10:25 AM
I wondered about that but since others have done this I assume the answer is no. Were not talking huge lengths of wire so I assume the additional resistance is negligible, assuming clean connections.
Old June 1st, 2011, 06:56 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Chaps, don't think of splicing the ECU harness your asking for trouble.
resistance changes in the joints aside you will not be able to seal the joint effectively, the conductor will corrode eventually kill the harness and possibly the ECU.
Bearmach sells the longer harness, i'll check on it and post back in the morning.
BTW i have seen a challenge truck that had the ecu mounted on the roll cage, and he just used scotch lock connectors to join 2 separate lengths together.
regards
Gren
Old June 2nd, 2011, 05:14 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Bearmach part number for the td5 ecu relocation harness is BA4202, i was quoted a trade price but expect retail is arround 200.
The harness is made by a company called dastek, both companies have US distributors.
regards
Gren
Old June 2nd, 2011, 07:20 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Probably safer just to swap to a diesel.
Tony
Old June 2nd, 2011, 05:08 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
OOPs complete brain fart.. i was thinking of a TD5 ECU...
I have the wiring diagram and specs for the v8 ecu's including the part numbers of the connectors, i just have to find the info, it's on a cd somewhere.
regards all
Old June 3rd, 2011, 04:04 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
custom engine looms for rover V8: http://www.lloydspecialistdevelopmen.../products.html
ecu
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
Interface on '94 ECU (OBD-I?) jaherring Defender Technical Discussions 10 October 11th, 2005 10:06 PM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
