ECU discovery=defender? - Defender Source
Old April 25th, 2006, 05:24 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Is a 94-95 discovery ECU the same as a 94 defender?
Pretty sure it is but, I'd like to know for sure before i drop the coin.
Old April 25th, 2006, 06:26 PM
Andrew Vick
Andrew Vick
95 D90
You should be fine. Lots of them were mix and match. Will they take it back if it doesn't work?
Old April 25th, 2006, 07:02 PM
They are slightly different. It "should" work. Lose the governor though. :-)
Old April 25th, 2006, 07:24 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Again, I'm running a 94 disco edu with the cold start / 4.2 chip in my 94 90. Has been in for 3-4 years. YMMV
cover, disco, discovery, ecu
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Interface on '94 ECU (OBD-I?) jaherring Defender Technical Discussions 10 October 11th, 2005 10:06 PM
ECU readout cbass Defender Technical Discussions 15 September 17th, 2005 10:05 PM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
