ECU diagnostic port doesn't work - Defender Source
Old April 5th, 2008, 12:23 AM
CWF
Clint Falk
97 D90 yellow ST
My check engine light is on and when I connect the Actron to the port[it will not link. I do have an aftermarket stereo on my 97 D90, which the amplifier has been removed. I remember reading something about the ground to the amp was also the ground for the ECU. I have tried to groung the wires from the wiring harness to the amp I must not be doing it right. Any help would be appreciated-Thank you.
ecu
Does a 4.2ECU work with a diagnostic display? Hans Defender Technical Discussions 1 February 14th, 2009 11:54 AM
Employment opportunity Rod Hayward Misc. Chit-Chat 18 December 20th, 2005 10:20 PM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
