ECU bad? - Defender Source
Old February 7th, 2012, 06:17 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
ECU bad?
So, my rebuild is to the point that I want to start the engine, but it won't. I've got spark so I think its fuel related.
With ignition switch in II position, the fuel pump runs for about 5 seconds, I've got pressure at the fuel rail, but I don't think the injectors are firing. I put a 12v bulb across one of them and nothing when I crank.
When I short pin 11 or 13 to ground on the ECU I get a nice squirt of fuel out of the injectors.
The ECU is turning on the fuel pump initially and throws code 02 when disconnected, so maybe its OK? Is it looking for some other signal (maybe RPM) before firing the injectors? According to the wiring diagram, pin 39 is connected to the ignition coil. Is this where it gets its RPM signal? Any other sensors that would prevent it from firing the injectors?
Old February 7th, 2012, 06:58 PM
coil?
Old February 7th, 2012, 11:23 PM
Silver relay. It could also be the ignition MODULE on the side of the distributor or on a plate near the coil (if it has been relocated).
My money is on the relay, but I had the module go bad from a short on chicky. You can check the relay by swapping them and if the fuel pump does not run when swapped, then it is the relay.
Old February 7th, 2012, 11:28 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
He could swap the two silver relays, and if the fuel pump then doesn't come on, than thats prob the culprit right?
Old February 7th, 2012, 11:31 PM
Yup. I was editing while you posted.
Old February 8th, 2012, 07:24 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
Both silver relays are fine. I have 12v on the injectors, but when cranking, the ECU is not pulling them to ground so they don't fire (squirt). Either the ECU is bad or it's waiting for some other signal, like rpm maybe?
I'm getting a good strong spark at the right time so I don't think it's the coil or ignition module (amplifier). I can't figure out how the ECU gets an RPM signal.
Old February 8th, 2012, 07:40 AM
Are you sure that you timed off #1 and it was on the compression stroke? #1 is the left front piston, not the right front like you'd expect. It is very easy to miss this and chase a ton of other things that are not the problem. Done this myself so many times.
If it was OK when you pulled the engine out, then the ECU is probably still OK now.
Go back, recheck everything one more time. Something obvious is staring you in the face and you aren't seeing it.
I will admit that the Lucas 14CUX has a nasty tendency to drop a bank without prior warning. It could be the ECU, but that would be my last resort after rechecking everything else
Old February 8th, 2012, 08:08 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
I'm pretty sure I got the timing right, but even if it wasn't, that wouldn't explain why the injectors are not firing.
It probably is something really obvious. My guess at this point is that the ECU is not getting an RPM signal, but I can't figure out where it gets it from and what type of signal it is (pulse or 0-5v)? From the wiring diagram I found, pin 39 on the ECU is connected to the coil, my guess is this might be the rpm signal, but I don't have any wires on the coil that go back to the ECU.
Old February 8th, 2012, 08:49 AM
Pretty sure this comes from the ignition amplifier module.
Old February 8th, 2012, 12:12 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
There are only 2 connections to the amplifier, 1 goes to the positive terminal on the coil and the other goes to the negative. Unless I'm missing a wire, there's nothing between the amplifier and the ECU.
Old February 8th, 2012, 12:30 PM
I think there's a wire from the neg side of the coil to the ecu. Thus, timing is from amp.
Old February 8th, 2012, 12:34 PM
Grover's Avatar
Grover
I delt with ignition issues last summer. IIRC, there is a white wire that connects to the coil (can't remember + or -) that triggers the ECU to fire the injectors. See pic...
Good luck...
Cheers...
Old February 8th, 2012, 01:22 PM
Also check the "chicklet"
Search and you will see what I am talking about.
Old February 8th, 2012, 01:44 PM
It's the thing taped up in the wiring going to the MAF
Originally Posted by pendy
I'm here for the D's
Old February 8th, 2012, 03:28 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
Thanks for the photo but it's too dark to see anything. How many wires do you have on the positive and negative terminals?
I had checked the "chicklet" before and got something like 6.8K ohms, it wasn't a dead short or an open so I figured it was ok, I'll search to see what value it should be.
Old February 8th, 2012, 05:36 PM
Grover's Avatar
Grover
I'll get a better picture tonight...
Old February 8th, 2012, 08:20 PM
Grover's Avatar
Grover
There is a white wire coming from the MAF loom to the (-) side of the coil.
Can you take a pic of your setup?
Old February 10th, 2012, 08:53 AM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
Here's my coil....
Old February 10th, 2012, 11:55 AM
Grover's Avatar
Grover
is your ign mod located on the dizzy?
Old February 10th, 2012, 12:06 PM
MAX711's Avatar
MAX711
Andrew Dance
1994 D-90 ST
Yes it is. 2 wires going to it, one to the positive and 1 to the negative on the coil.
I've traced one side of the "chicklet" to pin 39 on the ECU. The other side disappears into the harness and I can't see where it goes. I think I might try a jumper from this to the positive on the coil and see what happens.
ecu
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Interface on '94 ECU (OBD-I?) jaherring Defender Technical Discussions 10 October 11th, 2005 10:06 PM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
