ECU bad? - Page 2 - Defender Source
Old February 10th, 2012, 12:28 PM
Grover's Avatar
Grover
Originally Posted by MAX711 View Post
Yes it is. 2 wires going to it, one to the positive and 1 to the negative on the coil.
I've traced one side of the "chicklet" to pin 39 on the ECU. The other side disappears into the harness and I can't see where it goes. I think I might try a jumper from this to the positive on the coil and see what happens.
Do you have a white wire coming from the MAF loom to the (-) side of the coil?
ecu
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Interface on '94 ECU (OBD-I?) jaherring Defender Technical Discussions 10 October 11th, 2005 10:06 PM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
