ECM Replacement?? - Defender Source
Old November 24th, 2004, 09:10 AM
Rob
rob
1997 D90
Question ECM Replacement??
here are the symptoms:
97 d90 st
--when scanned w/ obd2 scanner i can get codes but not clear them
--scanner works fine on variety of other cars
--scanner will only scan when ignition is in ACC position (not when engine running)
--same results with multiple different scanners (inc rover scanner)
the only thing i can think of is that there is a problem in the computer somewhere - any thoughts?
do ecm's ever have to be replaced?
Old November 24th, 2004, 09:17 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Is the ECM causing/ behaving any differently, regardless of the scan? I can't vouch for OBD II scanners, but I "thought" they would not all work the same as say a dedicated rovacom tool. But maybe that's just me...
Old November 24th, 2004, 09:19 AM
Rob
rob
1997 D90
seems the same - the problem is that once a year in ny, u need to get the scan for inspection - they run the scan while the engine is running.....
ac
The age old replacement SEAT question michael15 Defender Technical Discussions 8 December 21st, 2005 09:22 PM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
ECM diagnostic output/interface on '94 jaherring Defender Technical Discussions 0 April 12th, 2005 09:48 PM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
Replacement Headlamps tuko Defender Technical Discussions 4 November 18th, 2003 09:51 PM
