ECM Relocate - Defender Source
Old June 22nd, 2009, 10:50 PM
Defenderbuser's Avatar
Defenderbuser
Chuck Duncan
1994 D90 Softop
ECM Relocate
Thinking about relocating my ECM to my Tuffy center console as it would be a lot drier location. Looking for input either way. Planning to cut the entire engine harness and extend it using well sealed Deutsch connectors. Thinking about relocating the main and fuel pump relays and fault display in there too. Thoughts?
Old June 23rd, 2009, 08:36 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Mike Hippert stuck his ECU into a tupperware container in the stock location and he's been known to sink his 90.
Jimmy Buffett
Old June 23rd, 2009, 12:32 PM
Defenderbuser
Chuck Duncan
1994 D90 Softop
Thanks for the info. Mine has had waterlines at the doorhandles a couple of times.
Old June 23rd, 2009, 06:26 PM
Anyone know of a source for the 14CUX ECU connectors (both the harness side and the ECU)? I guess I can scavenge both from a junkyard but figured they have to be available somewhere too. I want to make a "pass through" adapter that I can tap into and leave the harness and ECU stock.
thanks,
charles
Old June 23rd, 2009, 07:34 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I never could track down the AMP part number in any catalog. I do have an ECU side connector that I chopped out of one, which I don't need anymore. Open to any cheap offer for it :-)
-Hans
My oil line fix
My 100k stopped odometer fix
Old June 23rd, 2009, 08:23 PM
I'm all about cheap but don't know what to offer? PM me a price if you want.
thanks,
charles
Old June 25th, 2009, 06:34 PM
Defenderbuser
Chuck Duncan
1994 D90 Softop
I'm just planning to extend my harness by cutting somewhere in the middle. I'd consider going with a new connector at the ECM if I could source one; although your color coding on the wires would likely go out the window and you would have to rely on pin numbers for t/s.
ECM for 1994 ST Black_and_Blue Wanted 4 January 15th, 2009 07:05 PM
Relocate exhaust tip? Bozman Misc. Chit-Chat 11 June 6th, 2007 06:30 PM
numbering for the ecm pins? mattdh Defender Technical Discussions 2 April 26th, 2005 01:41 PM
ECM diagnostic output/interface on '94 jaherring Defender Technical Discussions 0 April 12th, 2005 09:48 PM
ECM Replacement?? Rob Defender Technical Discussions 2 November 24th, 2004 09:19 AM
