Easy transfercase oil change - Defender Source
Old August 24th, 2013, 04:22 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
Mcky D's straw and duct tape :-)
ID:	78225   Click image for larger version
Old August 24th, 2013, 06:58 PM
So there is some value going to McDonalds.
Old August 24th, 2013, 09:50 PM
molonlabedoc
Vincent
1987 D90
That's awesome. I used a weed killer spray via pump device. Worked like a charm, albeit slowly.
Old August 24th, 2013, 10:35 PM
They make pumps that go on the end of a gear lube bottle that cost less than $10... I have a 5 gallon bucket with a pump on top that I use. Everyone has their own way I suppose.
Old August 25th, 2013, 10:40 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yeah, between axles, gearboxes, transfer cases, I use a 5-gal pail with a pump on it.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Oil Change bjf Defender Technical Discussions 45 April 4th, 2009 02:05 PM
Smoke after oil change Montgo1715 Defender Technical Discussions 8 March 26th, 2009 11:44 AM
Oil and an ARB compressor amasaback Defender Technical Discussions 12 April 4th, 2006 02:22 PM
Draining Oil Made Easy Davis Defender Technical Discussions 14 March 5th, 2004 01:38 PM
