Easy heater removal ??? - Defender Source
Old October 9th, 2003, 09:12 PM
artm
Arthur Maravelis
97 SW
I have a '97 D90 with AC and need to get at the blower motor. The manual says remove hood, drain the coolant and remove the AC blower but I've heard otherwise. Can I do it a simpler way?
I think if I remove the ECU I can then get to the heater but removing the lower bolt of the ECU cover is already a pain. Also, getting at the screws in the footwell behind the AC blower seems impossible.
Any help appreciated.
-Art
Boston, MA
Old October 10th, 2003, 08:27 AM
This may help??
http://www.defendersource.com/faq/In...Heat.html#Core
But I remember someone else being able to get it out without removing the AC, but it was a real PITA.
heater
NAS D110 Heater Core Removal Jon_Winningham Defender Technical Discussions 6 January 8th, 2014 11:23 PM
School me on Heater core removal Buckon37s Defender Technical Discussions 23 September 15th, 2009 10:46 AM
Heater Removal Raider Defender Technical Discussions 6 April 12th, 2007 07:52 AM
Heater Improvements? And Hi ... again.. EdF Defender Technical Discussions 6 September 13th, 2005 01:51 PM
damn heater removal! alternative replacement? artm Defender Technical Discussions 7 October 15th, 2003 09:20 AM
