easy dent repair D90? - Defender Source
Old August 5th, 2010, 05:15 AM
hlamar's Avatar
hlamar
Heston LaMar
97 NAS D90 ST #1789
My D90 has a couple of minor "elbow" dents on the bonnet and one of the wings. They are only noticeable from certain angles, but they drive me nuts! They have been there since I bought the truck.
Has anyone ever used Dent Wizard or any similar such companies to do paintless dent repair on a D90? With the metal being so thin on these trucks, I was a bit worried to try it without others' advice. My paint is in very good shape, so I would rather not go with the traditional body shop repair.
Thanks in advance!
Heston
Old August 5th, 2010, 06:25 AM
Don't know about Dent Wizard, but there are a whole bunch of threads on dent repair. These trucks are aluminum...different beast than almost any other car found over here, so Dent Wizard will likely not apply. Don't know how many others are, but I believe DeLoreans and NSX's are on the short list of cars that are also aluminum.
I think aosias had some luck with one method a few months back. IIRC, Gustavo (and many others) have recommended gradual heat and manipulation; and others say not to do it.
Old August 5th, 2010, 06:26 AM
Deloreans are stainless right?
Old August 5th, 2010, 07:19 AM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
Right. Add Austin-Healey to the list. The big Healeys had aluminum center sections, though the doors and wings were steel.
John Karlsson
Hope Valley, RI
Old August 5th, 2010, 07:29 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
The main issue is aluminum stretches, regular sheetmetal will pop back into shape without distortion. I repainted my truck and got as close as possible and used a light skim coat of "Evercoat" filler for aluminum. If you can live with it, consider it adds character on the truck and not a trailer qeen, bumps will happen even with the best of care.
Old August 5th, 2010, 07:46 AM
Ha, OK that one was a stretch...it was 6am; I wasn't thinking straight. So, the list just got shorter.
Old August 5th, 2010, 10:13 AM
aosias's Avatar
aosias
Alexandra
1995 D90
I believe Audi has a few cars too. Call your local Audi dealer and see who they use. That's where I started and then asked the BMW dealer and Land Rover. There were a few body shops that overlapped. I tried several of the paintless folks here in Denver and none wanted to touch the truck, but in their defense my dents aren't just little dings.
I was able to use a torch and canned air to pop out one dent. Keep in mind that mine had paint damage too so I didn't mind. If you google DIY dent repair you should find a video or two showing this method. Basic idea is that you heat the metal with your torch- heat not cook- and then invert an air can and spray it on the heated dent. Mine just popped right back. The other one didn't budge. For my fender flare dent I was able to pull it out and work it out enough that the flare is attached properly but it's no where near perfect.
All my dents are the front outer wings so I could replace them but I'm being cheap- the paint is expensive and I've recently learned automotive painting and I are not friends in any way shape or form.
Old August 5th, 2010, 10:23 AM
Yeah, they're introducing more models in aluminum it looks like. Think it was just the A8 at first.
Old August 5th, 2010, 10:35 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Call the dealer in your area. They will know who can fix them.
We are lucky enough in Minneapolis to have one of the best paintless dent removal guys in the country...
http://www.juergensdentkraft.net/eng4.htm
Old August 5th, 2010, 11:13 AM
EricWS
Eric Siepmann
1966 Land Rover Series 2a SWB
Any good body guy can remove them. You will have trouble finding one that will try, especially when they hear the word aluminum come out of your mouth. The Dealer was the only on that would touch my 97 SW. And they did a real good job.
Old August 5th, 2010, 01:10 PM
bjf's Avatar
bjf
barry f
94 ST #395
Jag also has a bunch of aluminum cars.
I tried the dry ice method and it didn't work. I know Matt on the board has a guy in LA that does insane work on paintless dent removal on aluminum. I wanted to use him but haven't gotten around to it for door dings
Old August 6th, 2010, 12:50 AM
mpsteil
Michael Steil
NAS 110#23,97 ST#665
Doesn't MBZ also have a few aluminium bodies as well?
Old August 6th, 2010, 01:13 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Shit, Marcos used to have plywood chassis. You would fear termites more than road salt.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old August 6th, 2010, 09:28 AM
hlamar's Avatar
hlamar
Heston LaMar
97 NAS D90 ST #1789
As usual, thanks for all the great advice and occasional chuckle comments from the good people on the D-90 forum!
Heston
Old August 6th, 2010, 12:25 PM
Morgans had wooden chassis rails- add wet English climate....yikes
90, d90
D90 Repair In Socal Zimbo76 Defender Technical Discussions 6 January 31st, 2006 01:09 PM
1997, D90 50,000 miles or less JMPDIV82 Defender Technical Discussions 8 October 25th, 2005 10:34 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
