Easy alignment question probably... - Defender Source
Old October 27th, 2012, 12:17 PM
mattb's Avatar
mattb
Matt
94 D-90 No. 44
Hi All,
So I just replaced the ball joint at the end of the track rod but now my steering wheel is off by close to 20 degrees. What's the best way to correct this? When i installed the new joint I measured how far out the old one was but apparently I didn't get it correct.
Old October 27th, 2012, 01:36 PM
pull the cotter pin, remove the castle nut, loosen the clamps and pop out joint. loosen or tighten as required and reinstall. just slap the castle nut back up snug and drive back and forth in your driveway until you are satisfied with alignment. retorque to spec and install cotter.
Mark Kellgren
KM4BOR
Old October 27th, 2012, 06:09 PM
mattb's Avatar
mattb
Matt
94 D-90 No. 44
Thanks for the input. I guess I just needed a little more trial and error. 2 more turns and I have it straightened out!
alignment
Door alignment, adjustment question jayz Defender Technical Discussions 10 July 24th, 2012 12:07 AM
Lug Nut question: quick and easy fenwaystan Defender Technical Discussions 7 May 9th, 2010 10:20 PM
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
