Early Fuel Filler Hose Source - Defender Source
Old October 19th, 2015, 11:25 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I go to install my fuel filler and low and behold the hose is not going to fit.
I bought the hose over the summer and believe it is NTC2337 part. It is tapered.
I broke out the calipers and got just over 70mm for the tank and the filler neck. One side of NTC2337 fits the other is way too small.
I have been searching for a hose that will fit but no luck. Is it a better move to just buy the newer filler neck - NTC2676? Or is there a source for the older fuel hose?
Old October 19th, 2015, 11:44 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Good sources I think might help you are Trevor at Rovahfarm and Ike at Pangolin4x4. Might want to try to see if Uncle Doug knows anything and where to source the proper hose.
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Thanks Will!
Old October 19th, 2015, 11:51 AM
Get some silicone elbows from CXracing dot com. That's the easiest/cheapest way out of this pickle.
Old October 19th, 2015, 11:59 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Attachment 132756
Have a muffler shop build a taper onto the end of the hard-filler segment to fit the soft hose.
Old October 19th, 2015, 12:05 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I wish I realized this before I sent the piece out to get blasted and powdered - I would have stitched a reducer on there myself.
------ Follow up post added October 19th, 2015 12:10 PM ------
Thanks - the more I have been searching I will agree - going to look at CXracing right now.
Fuel filler Hose...Big $$,Any Options isleofbones Defender Technical Discussions 7 May 11th, 2011 08:28 PM
Source for fuel filler hose D90user Defender Technical Discussions 24 October 22nd, 2009 04:12 PM
WTB Fuel Filler Hose 97 D-90 wadaman Wanted 0 January 6th, 2009 08:32 PM
Air intake hose, fuel filler hose and neck SafariHP The Vendors Loft 0 May 18th, 2008 08:52 PM
fuel filler hose mattdh Defender Technical Discussions 2 October 31st, 2003 08:17 PM
