early 110 vs NAS 90 front driveshaft difference? - Defender Source
Old February 13th, 2015, 06:52 PM
phoenix37's Avatar
phoenix37
john
Hey guys I'm having a clearance issue with my tranny on this LS swap and the rear flange of the front driveshaft. are there any differences in the size of the shafts/flanges etc?.
Old February 13th, 2015, 07:08 PM
psykokid
Jake
1997 Disco
Not sure on the flanges but I know that they changed the driveshaft on the later trucks to a solid shaft in the front to give more clearance around the cats.
Old February 13th, 2015, 07:22 PM
phoenix37's Avatar
phoenix37
john
Thanks Jake… this is what I'm dealing with.. looks pretty wide and chunky (technical term) compared to the NAS ones i can find pics of online.
Old February 13th, 2015, 07:24 PM
Early trucks use 1310 u-joints which are larger than the normal 1300 joints. The flanges are the se but the joints are larger.
Old February 13th, 2015, 08:33 PM
psykokid
Jake
1997 Disco
Maybe see if anyone local has a later NAS 90 or disco front driveshaft to see if the smaller 1300 u-joint yokes will clear. The 1310 joints are .28" bigger across than the 1300's fwiw..
Old February 13th, 2015, 08:54 PM
phoenix37's Avatar
phoenix37
john
I have access to a disco 1 shaft.. Im going to see if i can grab it next week.
Old February 13th, 2015, 09:05 PM
disco 1 shafts are what I use. Solid = superior to the 90 shaft
Old February 15th, 2015, 08:47 AM
phoenix37's Avatar
phoenix37
john
pulled the front driveshaft last night… tried to move the truck this morning and the front transfer case flange spins but the truck won't move. difflock doesnt seem to be engaging even though the selector shaft is turned all the way clockwise.
This transfer case is out of a 98 disco… i removed the lock out solenoid.. Is there some other electrical solenoid/issue i need to address to engage difflock on this thing?!
Old February 15th, 2015, 04:53 PM
phoenix37's Avatar
phoenix37
john
thanks buddy… thats what i was looking for.
Old February 15th, 2015, 06:48 PM
phoenix37's Avatar
phoenix37
john
clearance issue solved.. early 110 shaft on the left disco1 on the right.
Old February 16th, 2015, 09:37 AM
phoenix37's Avatar
phoenix37
john
No, diff lock is a manual engagement. The solenoids only interfer with the the motion. There is a solenoid for high/low but not one for diff lock. However, the difflock light switch, if not adjusted properly and interfere with the internal linkage and keep the lock from engaging.
-Jeff
thanks Jeff! that worked.. pulled the switch and difflock engaged…
Old February 16th, 2015, 12:57 PM
Now adjust the switch per the procedure. Even if you dont, leave the switch partially in so you dont get grime in there. -Jeff
Plus the warning light is very helpful as driving around with diff lock on dry pavement will break something.
110, 90, drives, nas
Whats the difference between a US 1993 110 and a Canadian 1993 110? jjstahl3 Misc. Chit-Chat 2 April 19th, 2011 12:33 PM
ROW 110 Front Driveshaft Length Fuzzy Math Wolf Fabrication Defender Technical Discussions 10 April 5th, 2010 06:14 PM
ST vs SW Front Roll Cage Difference Wolf Fabrication Defender Technical Discussions 5 July 14th, 2009 11:02 AM
Front Wrap Around Bumpers - Is there a difference? NashvilleRover Defender Technical Discussions 1 September 14th, 2008 09:27 AM
Difference between the front grills aosias Defender Technical Discussions 3 May 27th, 2008 12:21 PM
