Early 110 hub help! - Defender Source
Old September 24th, 2012, 11:05 AM
andy110
Andy Bard
1986 110 CSW
Early 110 hub help!
I am in the process of replacing the swivel balls on my salisbury front axle and have run into a problem! Two drive member bolts have snapped off inside my hub!!!! They are snapped off about a 1/4 inch into the bolt hole. Can these be removed by a machine shop or do I need a replacement hub??
Old September 24th, 2012, 11:15 AM
They are 3/8 24 UNF, any machine shop should be able to get those out and clean up all the threads. They're threaded all the way thru except for a short overbore that helps get the bolts started.
Old September 24th, 2012, 11:17 AM
grnrvrs's Avatar
grnrvrs
Paul
88
With accurate drilling for a pilot hole in the broken off bolt and a bolt extractor and lots of PB blaster, you should be able to get them out. You can also consider drilling them out and re-tapping to a larger size.
Edit: Bill beat me to it.
1970 SIIA 88, Sold
Old September 24th, 2012, 11:20 AM
andy110
Andy Bard
1986 110 CSW
Thanks guys, I'll give that a shot tonight
Old September 24th, 2012, 11:57 AM
Those bolts are VERY HARD and difficult to drill (assuming they are the same as the later ones). If it were me, I would drop them off at a machine shop and let them deal with it as oppose to struggling and say breaking off an ez out in the bolt.
Old September 24th, 2012, 12:05 PM
Ya unless you have a big honking overhead drilling machine with a huge table and a way to precisely line up all the bolt holes yer sunk.
Old September 24th, 2012, 12:11 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Plenty of heat and an easy out might help.
Old September 24th, 2012, 01:07 PM
andy110
Andy Bard
1986 110 CSW
That is what I am going to try, I have a fairly large table top drill press/milling machine and oxy acetylene torch. If it starts to go south I will stop and send it to a machinist. If I destroy it I will be cruising EBay UK.
Old September 24th, 2012, 01:18 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Pictures?
Old September 24th, 2012, 01:31 PM
Or just grab another hub. I wouldn't spend money on something like that. Used hubs are a dime a dozen.
Old September 24th, 2012, 01:57 PM
Are the sals front hubs the same as other hubs? I thought they were different.
Old September 24th, 2012, 02:05 PM
Pretty sure they are the same from the axle tube out. Is the OP positive it is a Sals axle?
Old September 24th, 2012, 05:52 PM
andy110
Andy Bard
1986 110 CSW
Yeah, positive, I had it installed in the UK before delivery. Hubs are the same as early 110's. I may just hold off until I score a replacement, but damn I want this thing on the road ASAP
ID:	58018   Click image for larger version
Old September 24th, 2012, 06:49 PM
That's a pretty badass axle. I'd love a LHD one for the 2A.
Old September 24th, 2012, 07:58 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I drilled out and retaped 3 holes on one of the rear hubs on my NAS axle in situ late last year and then taped them to a US size this past spring. Was off road at RC with a locked rear-end and the stock bolts worked loose and I messed a couple of them up. Then again at RC this spring and the threads just wouldn't hold so went up a size on 3 of them.
Like ron/evilfij said - the bolts are hard but it is doable. One thing I have found with broken hardened bolts and taps is to get a punch of some sort in there and try and break them into smaller pieces. If you have the hub on the bench and with some heat and a drill press, I'd give it a go. Try and use the smallest bit you can and work up from that - go slow and lots of lube.
EDIT/Add-on - If the hub is specific to the Sals axle I'd probably wait and have a machine shop go at it.
Old September 24th, 2012, 08:36 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
take the bearings out and races ...heat that puppy up get yourself some wurth rustoff ice and a ez out
if not you should be able to drill and use a http://timesert.com/ or a keensert
No Mall crawler here
Old September 24th, 2012, 09:21 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Andy, I have a spare that had the same thing happen to one of the bolts. It was tapped out and drilled larger. At any rate if you need it i can bring it down this weekend. Those bolts are grade 10.9 or something so they are indeed very hard.
Land Rover 110
Old September 25th, 2012, 10:04 AM
andy110
Andy Bard
1986 110 CSW
Thanks Mike, I think I have it covered, Bill said that he has one he will send me. If that does not work out I may need yours though.
Early 110 split middle doors, any experience with them?? airbornrover Series Technical Discussions 6 May 13th, 2011 08:22 PM
Freshly galvanized early 110 cappings for sale Tyler Wirken For Sale - Parts 3 September 10th, 2009 08:34 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
