early 110 dash wiring - Defender Source
Old May 27th, 2008, 07:16 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I'm starting to get everything in place to install the new gauges in the 110. In poking around, I realized that the ovular panel in the center of the dash, unlike an NAS 90, actually has 2 gauge-sized holes and one small one, maybe for a cigarette lighter (see attached photo). I pulled it off and found that there's fabric behind it with openings in the supporting material for 3 guage-sized holes.
In digging a bit more, I found four wires under the plastic cover that sits in the center of the shelf -- a brown, a red, a black and a red/white (see attachment).
So it appears that there may have been some sort of option for accessory gauges in the center panel, and I'm assuming that the wiring powered them. Does anyone have any idea what these wires would power and/or what might have originally sat in that space? I'm guessing clock and cigarette lighter -- flasher switch is on the other side of the steering wheel.
And no, I haven't checked the wiring diagram (that I don't have) and I resemble a monkey pleasuring a football in using a voltmeter, so I'm looking for the easier answer here.
Name:	dash center web.JPG
ID:	13630   Click image for larger version
Name:	dash wiring web.JPG
Old May 27th, 2008, 07:35 PM
globallandrovers's Avatar
globallandrovers
Julian Kotting
1999 P38 DT, 1997 LHD 110 CSW
Location: Hertford UK, Wilmington, NC, Austin, TX and OH
Tony on checking the early 110 part book I have the holes are for in left to right order, PRC3115 Oil temp guage (left), PRC 2970 Clock (middle), PRC3116 (4cyl) or PRC3122 (8cyl) Oil Pressure Guage (right)
I can scan and email you the page if you require it.
all the best
julian
Land Rover Defender Specialist. - We ship worldwide.
We are a specialist in TDI re-power conversions, and Crate 'turn key' Land Rover TDI and TD5 engines and Transmissions.
Old May 27th, 2008, 07:57 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Fantastic, thanks, Julian! So the next question is what do those wires do? I'm guessing red=constant power, brown=ground, and the others are . . . errm . . . ahhhh . . .
Old May 27th, 2008, 08:06 PM
One is unswitched power, one is ground. I think another-small gauge wire is switched power from the light switch for guage and clock lighting. Mine has the square clock and power outlet/lighter in two of those spots.
Old May 28th, 2008, 11:12 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Basic rover color codes:
Brown: constant power unfused
Purple: constant power fused
Black: ground
Red/white: dash illumination
Green: fused power switched
White: unfused switched power
Email:
Old May 28th, 2008, 11:25 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks, Mike! What's red?
Old May 28th, 2008, 11:55 AM
to further elaborate
red is dash illumination
white is ignition 12v unswitched (i.e things that work only when the key is turned to ON- like ignition + on a petrol engine)
green is ignition 12v switched (things that work when the key is turned on but have their own switch- lights, wipers, etc
Old May 28th, 2008, 04:34 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
My truck originally had a Cig lighter, Rear wiper washer switch for the rear SW door and a clock in the middle...
Legend in My Own Mind.
110, dash, wiring
Late td5 dash wiring cabell Defender Technical Discussions 43 May 18th, 2013 08:22 AM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
