Dynamat on ST Doors - Defender Source
Old April 16th, 2012, 10:51 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Dynamat on ST Doors
As other threads have mentioned, it is amazing how well Dynamat silences road noise. You can now carry on a conversation and hear the radio -- such a novel thought! The kicker is that nice sounding thud when closing the doors. While the cards are out, it is also a good time to fog the inside of the door channels and the seam to the skin with Waxoyl. The thin tube that comes with the can is long enough to reach 100% of the channel through the screw holes. For reassembly, used those panel screws with the oversized washers from RN thinking they will help prevent tear out. Easy $50 project that goes a long way.
ID:	50404   Click image for larger version
ID:	50406   Click image for larger version
Old April 16th, 2012, 11:06 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
You gonna do the rear tub and footwells? Looks good! My defender had some Sound deadening when i bought it, never had to deal with it.
Old April 16th, 2012, 11:53 AM
down_shift's Avatar
down_shift
Russell
Thinking I am good enough in those areas by the rear rubber LR mat (the one that also covers the wells) and two sets of floor mats (the OEM insulated HD mats topped by the newer LR mats -- which are thin crap). I have an extra sheet and half of Dynamat remaining so I might do the bottom of the seat boxes and just up the sides to the floor elevation and stop there.
Old April 16th, 2012, 05:35 PM
Spook's Avatar
Spook
Rich
97 Defender 90
I have two rolls to get down to business. I just have all the projects lined up. Waiting to take the top off to get in more area. I plan to dyno mat a lot of the areas and shoot the rest with the dynamat spray in the tub and the fiberglass top.
Old April 16th, 2012, 05:43 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I solved my road noise problem with an extra battery, bigger amps and more speakers with a 15" Kicker sub.
Robert Deniro
Old April 16th, 2012, 06:37 PM
Thats noise pollution.
Old April 16th, 2012, 06:59 PM
Neil McCauley
Neil McCauley
Really depends on what you consider noise pollution. Personally I like loud music.
Robert Deniro
Old April 16th, 2012, 10:31 PM
founD90's Avatar
founD90
Dr. Gonzo
1994 D90 #48
Sounds like a good project. Can you explain what you mean by fog? Maybe some pictures?
Thanks!
Old April 16th, 2012, 11:08 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
The fog is what comes out of the nozzle of the clear waxoyl. It is what you are supposed to put in your frame cavities, door bottoms, and hinges every now and then.
When it comes out it looks like a fog and coats everything well.
Old April 18th, 2012, 10:59 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Russell, I've read/heard doing the underside of the hood makes a remarkable difference too.
Clay
Old April 18th, 2012, 11:03 AM
bjf's Avatar
bjf
barry f
94 ST #395
With a v8 I don't see why you would need to. Tdi is a different story
Old April 18th, 2012, 12:20 PM
down_shift's Avatar
down_shift
Russell
Clay
Looking to leave the hood alone (and any other visble place alone). Besides, I can't even hear the engine above the growling of your old KM2s!
Swapping out the y-pipe with the Magnaflow cats to the used D1 factory y-pipe/cats made the engine sound wimpy. I had no idea that cats could make that much of a difference so I'll swap out the one bad Magnaflow cat and put that y-pipe back in.
Old April 18th, 2012, 03:37 PM
I'd solicit some opinions on your y-pipe theory as I too wouldn't think the cats would affect the engine noise unless that noise was your engine begging for the cat to be replaced. But I'll buy the y-pipe back if you do swap it out
Now a magnaflow exhaust is a different matter.
Originally Posted by pendy
I'm here for the D's
Old April 18th, 2012, 04:00 PM
down_shift's Avatar
down_shift
Russell
The D1 y-pipe works great, thanks! No issues on that front. The magnaflows produced a throaty growl guessing due to their "high flow" design or marketing BS. They peformed and sounded like a champ when you got on the gas until the left side gave out causing the blockage (not a quality issue of the cat, due to the abuse of tooling around with the #3 and #7 wires being swapped in a prior life). As for opinions, don't know, but a quick google search shows the same thoughts in the jeep world. Perhaps is a placebo but not to my ears of of my son's. LOL
http://www.jeepforum.com/forum/f221/...verter-770715/
Old April 18th, 2012, 04:07 PM
Maybe the "high flow" does that - just didn't think it could/would make a difference! I've never noticed a difference in sound between the aftermarket cats I am running now and two different stock setups on the same truck but it could also be my untrained ear and the fact that I prefer not to hear the exhaust over the engine.
Old May 14th, 2012, 03:11 PM
pdella
Paul
1997, Defender Alpine White
I am considering using Waxoyl vs Ziebart- there is no Waxoyl rep in the DC area and would have to drive all the way to PA or Conn to get it done and it will cost 2x.. I do it my self- the spray equipment is close to $400... how hard was it to do yourself? can you contact me directly for a few questions? 703-625-3746
Old May 14th, 2012, 06:28 PM
down_shift's Avatar
down_shift
Russell
You can purchase the thin Waxoyl from Rovers North. About $20 for a large aerosol can. It comes with the long spray tube and fitting. Join us at happy hour this Thursday and we can complete a door for you. Easy project. Kilroys in Fairfax.
Old May 14th, 2012, 08:40 PM
pdella
Paul
I won't be able to make it- out of town on Thursday...bummer.. Interesting alternative on the Waxoyl, I will check into it. what about the undercoating stuff that they sell- don't you need to buy the spray gun that they sell? Where do you suggest I take the truck for repairs in the DC area? I have a ton to stuff to do the the truck.... I would welcome the opportunity to pick your brain on a few items- Newbee..
Old May 24th, 2012, 01:35 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I used marine insulation from West Marine - the stuff they use to insulate inboard motor cowlings from noise and heat - in my doors. It works great, has a very satisfactory-sounding thud when closing, and road noise is substantially reduced.
The WM stuff is self-sticking, then foam, then a suspended layer of some kind of rubber, then foam, then reflective mylar. It's tough stuff, too, being meant to go on boats. I was thinking about doing under the hood as well and perhaps the firewall in the engine compartment.
Old June 11th, 2012, 12:11 PM
pdella
Paul
Thank you!
My son and I did the door project this weekend and good thing we did- door seals were leaking and rust was forming inside the rails! We used the waxoyl in the screw holes like you described, installed the dynamat inside the doors and going to replace the window/door frame gasket. Love the solid sound of the door closing and the door speakers sound much better- Great project!! Thank you for posting it!
door
Switch from ST doors to SW doors TAIIISI Defender Technical Discussions 5 August 29th, 2005 12:27 PM
Switch-out HT Doors w/ ST Doors 1of40 Defender Technical Discussions 11 May 2nd, 2005 09:04 PM
Trade: ST doors! TwisteD90 For Sale - Parts 1 July 15th, 2004 07:55 AM
ST doors an SW rover4x4 Defender Technical Discussions 6 October 6th, 2003 02:29 PM
