Dynamat Fail - Defender Source
Old December 22nd, 2012, 03:01 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Dynamat Fail
I recently installed dyna-mat on my 110. This is just my 2 cents on the results of the install for anyone considering throwing down the cash to dynamat their roof. BLUF: based on data collected, it isn't worth it to dynamat your roof for sound purposes alone. I ordered a set of 9 18"x32" in a bulk pack from amazon. It covered the whole roof except for about 4 square feet of the roof in the rear of the truck.
I conducted multiple in-truck decibel readings prior to install. I did not expect sound reduction below 50MPH, but I did expect at least some reduction in wind noise at highway speed. Decibels prior to installation were 88-90 at 60 MPH. After install there was zero reduction in recorded wind noise. 'Feel' in the truck reflected the data... I felt no notable decrease in cabin noise at highway speeds.
Next step will be the bulkhead, doors and seat box. I expect some reduction in road/engine noise with these upgrades. This upgrade has dropped in priority after seeing how little it helped on the roof.
Other data, by average:
In truck with engine off: 43 decibels
Idle: 75 decibels
45 MPH: 80 Decibels
55 MPH: 88 Decibels
Max decibels: 94
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old December 22nd, 2012, 03:09 PM
grnrvrs's Avatar
grnrvrs
Paul
88
What were you trying to accomplish with dynamat on the roof? It partially mitigates vibration in body panels (drum effect), but does little to nothing to block or absorb errant sound. Acoustical foam will absorb errant sound while dense mats are designed to block sound transmission. Different tools for different jobs.
1970 SIIA 88, Sold
Old December 22nd, 2012, 03:12 PM
ontheway's Avatar
ontheway
Dave
The reverberating drum effect of my rolling tin can was what I was trying to help.
Old December 22nd, 2012, 03:28 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I added 5692t49 @ Mcmaster.com, stem to stern and then put in the headliner. I too found that dynamite by itself did little, because all of the errant noise just bounced around. After the acoustical foam, it was way better. How are your door seals? Are there any holes in the bulkhead (either rust or open bolt holes). Pin holes can let in a surprising amount of sound. Are there effective gaskets/strip caulk seals for all of the floor plates?
1970 SIIA 88, Sold
Old December 22nd, 2012, 03:35 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Dynaliner
I went with a base of Dynalmat and then 1/4" Dynaliner on the roof and bulkhead. On the floor I had carpet made with thick backing. Still in process but I can already feel the difference.
Name:	2012-11-27 17.17.43.jpg
ID:	63191   Click image for larger version
Name:	2012-12-09 11.54.21.jpg
Name:	2012-12-09 13.40.12.jpg
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old December 22nd, 2012, 03:47 PM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
I feel with the diesel the largest improvement would be with the front floors and bulkhead
My other car's a Land Rover
Old December 22nd, 2012, 04:02 PM
Roving Beetle
Doug
As a cheap ass and loving to DIY things - I have conducted tests and found that "Grace Ice and Water Shield" 2 layers thick works as well and possibly better that Dynomat extreme. And at a FAR lesser cost. God help you if you ever have to remove it, a good and bad thing. Good in that it won't allow water under it to fester but bad in that it's a bitch if you need to remove panels.
Also it is ONLY good as a base layer and needs to be topped with foam decoupler of some sort to really get a noticeable effect. (This is why it often helps inside doors or under carpet - you need another layer to block the sound transmission)
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old December 22nd, 2012, 05:16 PM
What he said. When I did my roof, I did add some rectangles in the center of each large roof section to dampen the noise, but I new my noise issues where not coming from above. My focus on the roof was in thermal insulation, and that is what I did to the whole length of the roof. I used Second Skin insulation and it made a HUGE difference in the effect of A/C in the summer and keeping in heat in the winter.
Mark Kellgren
KM4BOR
Old December 22nd, 2012, 06:27 PM
http://www.mcmaster.com/#standard-fo...lation/=kpipbz I recommend 5692T14, which is non-adhesive backed, but I have a prejudice against adhesives on the Defender
Old December 22nd, 2012, 06:36 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
Agree with everything said thus far
Dynamat alone will not do enough. I did the entire roof and its hard to tell if Dynamat alone helped with noise because I'd been rolling around with no headliner for a year and installed the headliner at the same time as I installed the Dynamat. There was a noise reduction, but not as much as I thought I'd observe. I had also added a thin layer of 1/8" foam on the headliner before headliner fabric. Don't know if that helped, I was not that scientific about it.
When I was doing some work over the past week, I had removed the rubber matting over the transmission tunnel and part of the bulkhead and the noise increase was DEAFENING! Noise back to normal when I reinstalled the OEM rubber matting. I agree with others who suggest that the FLOOR, not the roof is the answer in terms of cutting the noise.
I do not want to Dynamat the floor or inside of bulkhead as it would be ridiculously hard to make any repairs. Likewise, Dynaliner would do a great job, but I really want something that you could remove occasionally so I can hose out/vacuum out the floors.
I'm researching heavy duty 1/2 - 3/4" rubber matting that can be cut for the floor and will hold a shape and run up the inside of bulkhead. I've already got the tunnel and center section of the bulkhead around the fuse panel covered. I don't think spending $$$$$ on HD load mat is what I want to use, but something of that type, but maybe thicker?
Also plan on looking through McMaster for some engine bay liner for under the bonnet and in the engine side of the bulkhead.
Old December 22nd, 2012, 06:40 PM
Jackie Treehorn
A
1985 (legitimately)
More pics
Don't know why I can't post more than one pictur at a time with iPad?
Old December 22nd, 2012, 06:42 PM
Jackie Treehorn
A
1985 (legitimately)
Exactly!
Old December 22nd, 2012, 07:22 PM
ontheway's Avatar
ontheway
Dave
I experienced the same thing.. It made me glad I didn't get an ex-mod truck.
Old December 22nd, 2012, 07:48 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
I would thing doing nothing with the support channels on the roof would lessen the reduction. Has anyone injected foam or anything of the like into those hollow channels?
Old December 22nd, 2012, 07:54 PM
Jackie Treehorn
A
1985 (legitimately)
From a noise perspective, probably great....
From a rust perspective, probably not so much (imagine how that would hold moisture)
Old December 22nd, 2012, 08:08 PM
recently released exmod trucks have the killer wright offroad sound matting sold by exmoor
Old December 22nd, 2012, 08:13 PM
ontheway's Avatar
ontheway
Dave
I recant my previous statement.
Old December 22nd, 2012, 08:20 PM
Jackie Treehorn
A
1985 (legitimately)
McMaster Carr is where it's at!!!!!
Could spend all night ordering stuff.
Definitely ordering some of that sound material.... And the stuff for under the bonnet
To bad it's too late to make it on Santa's sleigh
Old December 22nd, 2012, 08:38 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
This one needs a bunch of soundproofing!
Old December 22nd, 2012, 10:29 PM
ontheway's Avatar
ontheway
Dave
Haha look at that, you spotted me. And as usual my truck was one of the last ones in the parking lot.
Dynamat on ST Doors down_shift Defender Technical Discussions 19 June 11th, 2012 12:11 PM
How much Dynamat to order for a 110? Yudda Defender Technical Discussions 9 November 16th, 2010 02:04 AM
Dynamat in a Soft Top Grover Defender Technical Discussions 2 December 23rd, 2009 10:15 AM
Dynamat Grover Defender Technical Discussions 15 June 4th, 2009 08:11 PM
110 Wheel Cylinders - How often do they fail? COSteve Defender Technical Discussions 7 March 11th, 2005 04:27 PM
