Dynamat - Defender Source
Old June 2nd, 2009, 12:33 PM
Grover's Avatar
Grover
Question Dynamat
For those of you using dynamat for sound deading:
I would like to put down some dynamat however I do not want to glue or use adhesive. I like the ability to remove all carpeting and clean it out. I think if the dynamat was glued to the panels, it would made cleaning it out a real pain. any thoughts???
Cheers...
Old June 2nd, 2009, 12:38 PM
bjf's Avatar
bjf
barry f
94 ST #395
You could always lay it down but not peal the film that covers the tape. If this is your goal though this may not be the stuff for you. I have it in both of my trucks but I use it in places that wont get wet or dirty. In my 90 it is in my doors, behind the kick panels and under the load mat in the back which i don't remove. I say use it in doors and use a souond deadening rubber mat on the floors if you are worried about removal
Old June 2nd, 2009, 02:32 PM
CDeWan
Clay DeWan
5.3L beastie
I went the same route as Barry did. If you have access to a pick your parts, you can pull the sound deadening mats out of a disco or classic (and cut to fit) and put it underneath your load space in the back and floor mats. It is a fabric foam with a rubber backing. Also for under the seat area, you can buy the TD5 seat box cover from rovers north which will help deaden the sound from the drive train.
Old June 2nd, 2009, 03:37 PM
does anyone have one of the exmoor TD5 rubber mats installed and can take pictures of it?
95' D90 - daily driver..
Old June 2nd, 2009, 05:16 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have the genuine td5 mat in the front
Old June 2nd, 2009, 08:37 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Just installed dynamat in my 95sw and cant believe the difference even with the tdi. So much quieter then my ST. I will be doing my rear tub on the ST asap..
Legend in My Own Mind.
Old June 2nd, 2009, 08:44 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Randy,
Where all did you install it in your SW?
Old June 3rd, 2009, 07:25 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
bonnet, rear tub, seat box, floor, bulkhead and doors. My ST has the bulkhead and doors done but I think the bonnet and rear tub helped a lot
Old June 3rd, 2009, 07:28 AM
does it help with the heat? I am going to ditch the cats and do some header wrap on the exhaust.
Seems this has become the summer of trying to cool the Defender down. I wish someone would hurry up and buy this thing.
Old June 3rd, 2009, 08:26 AM
Epsom_D2
Sean-Paul Ferrera
1994 D90 POE
Pull up your floor boards clean the panels and use peel and stick roofing material on the underside. It has similar sound deadening capability and greater R-value so it shields heat better than the dynamat. Not to mention it is cheap as chips especially when compared to the dynamat.
S-P
Old June 3rd, 2009, 10:18 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
S-P
I have seen this done before, with OK results, except the interior of the vehicle smells like a tar pit on a hit day. Your results may vary.
You aren't falling for the old "header wrap on the exhaust" trick are you?
Old June 3rd, 2009, 05:32 PM
I guess I am. Ive run out of ideas?
Old June 3rd, 2009, 11:23 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I didnt use Dynamat but used Peel and Seel, 100sq feet for about $90. I did my roof, hood, all floors, bulkhead, seat boxes and transmission tunnel cover, oh, doors too. HUGE change in noise and heat transfer. I still had a bunch left ovr for other projects. Dynamat will do the same thing for you.
I drove to Death Valley last week in temps around 100. The roof on the inside was always cool to touch with the Peel and Seel. I could also listen to the radio and carry on a conversation with those sitting in the back seat whithout yelling. So much better
Old June 4th, 2009, 06:55 AM
Grover's Avatar
Grover
Question
Peel and Seel...where did you purchase it?
Old June 4th, 2009, 08:11 PM
CDeWan
Clay DeWan
5.3L beastie
Went to the junk yard and pulled from the full size Ford or Chevy vans the aluminum with fiberglass backed engine cowling cover. As it is very plyable, I stuck it above the tranny and zip tied it in place. Works great and cheap at both heat and noise reduction. Wrapped the Y pipe after the cats and that helped too on heat.
kellymoe's Avatar
kellymoe
kevin
defender 130
I bought mine at Burbank Hardware a few years back for just under $90. This is the cheapest I have seen it online.
http://www.hardwareandtools.com/invt/9789520
How much Dynamat to order for a 110? Yudda Defender Technical Discussions 9 November 16th, 2010 02:04 AM
Dynamat in a Soft Top Grover Defender Technical Discussions 2 December 23rd, 2009 10:15 AM
Dynamat TDI Guy Defender Technical Discussions 20 March 20th, 2009 07:55 PM
Dynamat extreme in Montreal Santiago Defender Technical Discussions 14 May 14th, 2008 12:10 PM
Dynamat or Ice & water shield JBOD77 Defender Technical Discussions 15 October 13th, 2007 11:00 PM
