Dynamat - Defender Source
Old March 17th, 2009, 11:06 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Dynamat
where is the cheapest place to buy this stuff?
Legend in My Own Mind.
Old March 17th, 2009, 11:09 AM
bjf's Avatar
bjf
barry f
94 ST #395
I did ebay
Old March 17th, 2009, 11:26 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I've got a ton of leftover B-quiet if your interested in it.
Old March 17th, 2009, 12:18 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I used this stuff to do my 130. http://www.hardwareandtools.com/invt/9789520
I did it about 5 years ago and could not be happier with the results, no downside at all. It made a huge difference in sound and heat transfer from the engine compartment. I bought 99 sq ft. for $89 5 years ago and I am sure if you look around you can find it cheaper than what this site has it listed for.
Old March 17th, 2009, 01:42 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Dynamat is hugely expensive !! The exact same stuff is for sale in McMaster Carr (less the name) for 1/2 the money.
Dennis
Old March 17th, 2009, 05:10 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
x2. That's where I bought mine for the 110.
Chance
Old March 17th, 2009, 05:55 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
KEvin, what do you have left?
Old March 17th, 2009, 06:01 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I think I have about a 3'x5' piece left on the roll. What are you using it for? If you just need a bit I could send you some.
Old March 17th, 2009, 09:18 PM
Lee
Lee O
95 NAS D-90 300Tdi
Maybe more info than you need:
http://www.sounddeadenershowdown.com/
They're not a big fan of the ashpalt-based mats. Dynamat has great marketing.
Old March 17th, 2009, 10:00 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
They're not a big fan of the asphalt-based mats. Dynamat has great marketing.
Here is my experience with an asphalt based product, Peel N Seel.
It was relatively cheap compared to Dynamat $89 for almost 100 square feet.
It was easy to apply if the surface is clean, this goes for Dynamat too.
With the aluminum face it does a good job of reflecting heat away from floor boards and firewall.
I have had zero issue with tar or asphalt smell. 5 years ago when I first installed it in my truck, I applied it to the ceiling of my truck to cut down on heat and the tin can sound. After installing it I went on a trip to Death Valley where temps reached well over 100 degrees each day for the 4 days I was there. No smell, none.
I have had no problems with it coming undone.
The only issue has been the layer I placed under the floor mats. It is starting to wear through from rubbing. I would assume Dynamat would face the same problem. I have plenty left over from my original roll so I'll just slap some more in when the time comes.
I have been very impressed with Peel N Seel. I can hold a conversation and listen to music , I could not prior to installation. Could not be happier.
Old March 18th, 2009, 12:36 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Get the Ultimate from www.b-quiet.com it is the same thing and half the price. Keep in mind you want to use a proper noise barrier on top and don't do more than one layer of matting or you're just adding weight.
Old March 18th, 2009, 01:00 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Your not going to put that stuff down on your beautiful D-90 are you?
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 18th, 2009, 10:57 AM
ajh
Andrew J. Hutton
Depending on where you are working there are often better alternatives for mass-loading for vibration damping. Bedliner on the outside of the panels (non-cosmetic bodypanels of course) is dual purpose for both protection and vibration. Inside if you want less noise you need a mass loaded decoupled noise barrier like lead sandwiched in neoprene or mass loaded vinyl laminated to neoprene (or another closed cell foam).
When I finish my reassembly I will publish details and noise figures as improving cabin comfort is one of my priorities.
Old March 18th, 2009, 01:36 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Second Skin Audio ...
I went for Second Skin Audio Damplifier Pro and it was a little pricy but not a whole lot more than Dynamat. Sticks like hell and easy to work with. I like the sounds of the "thomp" my doors now do when I close them, and it made a hell of a difference in the audible comfort in the cab as well. I am getting the floors and tub Linexed next month and will report back for the complete result.
I also used there closed cell foam under the diamond plating on the wing and bonnet witch helps allot and planing to do the under hood too with the Damplifier Pro.
Pat
Kirk Lazarus, Tropic Thunder
Old March 18th, 2009, 05:36 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Part #?
Old March 18th, 2009, 06:05 PM
bjf's Avatar
bjf
barry f
94 ST #395
I had been using dynamatt extreme but if there is something equivilent and cheaper, sign me up.
Old March 19th, 2009, 10:41 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I just use it for the floor of the rear tub, firewall and seat box...
Old March 19th, 2009, 12:09 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Try this search: http://www.mcmaster.com/#sound-contr...lation/=12kn8i
Look for sound vibration deadening sheets.
Dennis
Old March 19th, 2009, 12:16 PM
chris snell
Chris Snell
87 Ex-MOD 110
Do you have a carpet set in your truck? What are you putting on top of it?
Old March 20th, 2009, 07:52 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I will need some new carpet eventually..
How much Dynamat to order for a 110? Yudda Defender Technical Discussions 9 November 16th, 2010 02:04 AM
Dynamat in a Soft Top Grover Defender Technical Discussions 2 December 23rd, 2009 10:15 AM
Dynamat Grover Defender Technical Discussions 15 June 4th, 2009 08:11 PM
Dynamat extreme in Montreal Santiago Defender Technical Discussions 14 May 14th, 2008 12:10 PM
Dynamat or Ice & water shield JBOD77 Defender Technical Discussions 15 October 13th, 2007 11:00 PM
