dynaliner on exterior side of wheel well - Defender Source
Old March 17th, 2013, 12:30 PM
sro
Sam Odio
2008 LR2
I'm thinking of putting dynaliner on the exterior side of the wheel well and possible elsewhere under my d-90. Don't want it on the inside because I don't want to have to put a rubber mat (or similar) over it.
Has anyone done this before? Any thoughts?
Old March 17th, 2013, 02:21 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Are you talking about Dynamat? Or a spray liner? I had luck with both, it is all in the prep work! I like to dynamat first them spray bed liner over it. Wether it is commercial grade like lineX or rhino liner or DIY like monsta liner or equivalent. I would only use a two stage DIY if you do it your self. Also I would heat the Dynamat to make less wrinkles so it is harder to tell that you used it! Especially this time of year. The two pics are from my bulkhead. You can do this to anything, I also did it to the bottom of my truck!
ID:	68307   Click image for larger version
Old March 17th, 2013, 04:22 PM
sro
Sam Odio
2008 LR2
I was thinking of this stuff: http://www.dynamat.com/products_auto...dynaliner.html
"Dynaliner isn’t affected by oil and does not absorb water. Dynaliner provides acoustic isolation and excellent thermal insulation for roof, firewall, floor, quarter panels, doors and even as a hoodliner."
I have some Herculiner. You think I could use dynamat xtreme beneath the vehicle and put Herculiner over it? I assumed you couldn't really paint the stuff (but I haven't seen it before so I don't know really what it's like)
Old March 17th, 2013, 05:26 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
I haven't personally used dyna liner, but if it is was I think it is, you cannot spray a liner over it bc it is a foam product. The best results I have had is with dynamat, and spray liner! It dampens sound and vibrations. I am not a fan of herculiner, even with proper prep it has a tendency of chipping. If you do it use a two stage with a base and catalyst, this is a stronger product and if installed properly won't chip!
wheel
removing steering wheel Hollywood Defender Technical Discussions 25 August 15th, 2010 03:16 PM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
Steering Wheel Sleeve mpodgorski Defender Technical Discussions 5 December 12th, 2005 10:46 AM
Front Wheel Bearing replacement flippedrover Defender Technical Discussions 11 December 21st, 2003 11:44 PM
