Dynabeads or Equal ? - Defender Source
Old September 7th, 2010, 11:02 PM
Want to try something else. Opinions or experiences to share ?
Old September 7th, 2010, 11:10 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
running dynabeads in my 37" Irok on my d2 and they work well, not sure how well they'll work in a colder environment, but out here in the oven, I have zero issues and really can't tell the different between this set up and wheelweights...
Old September 8th, 2010, 12:05 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Oh man.
Don't waste your money. Equal was the worst thing I ever bought for my truck. I'm kind of pissed that EE still sells this stuff and markets it like it's good. It sucks.
$75 for the equal
$30 to get the tires remounted with the Equal
30 minutes trying to air down my Equal-filled tires at SCARR
Four weeks driving around on the most awfully-behaved unbalanced tires.
$30 to get the Equal vacuumed out of the tires and get them re-balanced with weights.
So, roughly $135 down the drain plus several hours wasted.
I could have bought two nice bottles of port for that.
Old September 8th, 2010, 12:09 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
good points Chris...I guess I should have added I'm running Powertank's Monster Valves also...
Old September 8th, 2010, 12:20 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I used dynabeads in 235/85 muds for a while with nothing but delight. I believe they work best with narrow tires though.
I rotate 6 through and have had no problems. I used to have issues throwing weights on washboard, but now no balancing issues ever for many miles on bad roads.
Old September 8th, 2010, 12:39 AM
Chris my brother Cabell is running equal and bitches about slow airing down but he hasn't been following the instructions that say put some air in the tire first to clear the valve stem screen. I have seen a couple of complaints about Equal but none for the dynabeads. Steve and Frank thanks for the feed back. Any suggestions for who sells dynabeads ?
Old September 8th, 2010, 02:01 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
I've run both. Had no problems with equal and airing down. Dynabeads are the same in my experience. I did all the installation myself. It's quick, easy, and works great. Dynabeads are slightly bigger in size of beads. You can install dynabeads without removing the tire. You can also do the same with equal. Equal worked great for balancing in my old 285/75s and dynabeads are still working great for balancing in 255/85s. I'd recommend either.
You little rebel, I like you.
Old September 8th, 2010, 06:36 AM
dchapman
Daniel Chapman
1999 D1
I've ran both. I'm back to lead weights now, if that tells you anything.
The beads were ok. I ran them in 35x13.50 BFG Krawlers on beadlocks, and I ran them on the LR3. They were fine. However, there is nothing better than lead weights. They may get ripped off every-so-often off-road, but it's a much better ride.
If you wants some beads to try, Doug, drop me a note.
Old September 8th, 2010, 08:20 AM
I ran Equal for about 4 years, Put them in my 255/75/16 BFG KM1s when I first installed them. Balance was great until this year, then I started picking up a vibration that I couldn't shake. ( I was also gone for military deployment for 1.5 of those 4 years). Thought it was driveline, but it was the tires. I rotated them, and it didn't resolve the issue. It was a minor vibration but annoying for long trips.
I called the tech support of Equal, and they said that Equal was never intended for passenger car/light duty truck. It was for commercial big rig applications, and that they don't test or warranty the product on light duty applications. They said the tires have to be much bigger/heavier than light duty size for equal to work properly.
After that call, I had all 5 tires vaccumed and ballanced with lead weights. I'll be sticking with that.
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Crosman Airsoft BB's. cheap, won't rust or clump, and work exceptionally well. I can drive down the highway with my hands off the wheel and get no wiggles with 285/75-16 SSR's.
http://www.crosman.com/airsoft/ammo/SAP5020
Old September 8th, 2010, 09:22 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
I have been running dynabeads on like 4 or 5 different tire combinations from 285s to two different sets of 36s and I love them. I have a lot of experience trying to balance large wheel tire setups with lead weights and its tough to get right and you have to redo it often, for me the beads have eliminated that. Ive never had an issue airing down the only drawback is if you change wheels or tires you are basically gonna lose those beads. I had equal in a set of tires and it clumped which is worse than no balancing if you ask me. I bought another setup with steel bbs in them and didnt like them, never tried the plastic since I have had success with the dynabeads.... Justin (Lucky8) sells them
Old September 8th, 2010, 12:01 PM
My Harley fatboy had Dynabeads so I know they work well in small/bike tires. I have a set of 285 Km 2's that I now have 23k on. The tires were on alloys and balanced fine. They took a lot more weight when I put them on the Wolf/Nato/130 wheels and I think I'd like to try the beads to see if I can regain some ride quality- and squeeze another 15k out of these great tires. Thanks for the heads up I'll call Justin.
Do Dyna Beads require special valve steams like equal ?
Old September 8th, 2010, 01:12 PM
grnrvrs's Avatar
grnrvrs
Paul
88
According to Innovative Balancing, yes:
http://www.innovativebalancing.com/service.htm
Old September 8th, 2010, 02:12 PM
dchapman
Daniel Chapman
1999 D1
Doug,
I have about 50lbs of beads. You're welcome to whatever you need. Just let me know.
Old September 8th, 2010, 02:25 PM
Dan,
Looks like I need about 32 oz's per Dyna Bead. I need more stickers from you anyway. Email coming your way.
Old September 8th, 2010, 05:01 PM
crown14's Avatar
crown14
Verticalscrote
The correct beads do not require the special valve cores but I used to run them anyway. I dont now and have no problems.
Old September 15th, 2010, 01:43 PM
Dan,
Got the beads today. Many thanks. Had to call Innovative and ask where the hell the 5 valve stems and other stuff I ordered last week is. Hopefully will be on the road with that setup on Friday.
Old September 15th, 2010, 01:56 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Doug, you could get a set of these...
http://www.powertank.com/products/sfID1/15
Monster Valves...I run them on my Irok's and can deflate to 10 psi in about 40 seconds, refill in about 1 minute...
Frank
Old September 15th, 2010, 03:24 PM
Looks like a neat product Frank- but the other folks already have my money
Old September 15th, 2010, 03:40 PM
I like the look of those monster valves, but they look like they would be pretty easy to tear up on the trail.
Are 200tdi timing belts created equal? alastair Defender Technical Discussions 9 June 15th, 2010 04:41 PM
Need Equal Tire balancer feedback Overlander Defender Technical Discussions 26 June 14th, 2010 01:41 PM
Tires: an odessy souza Misc. Chit-Chat 37 December 14th, 2009 05:57 AM
Equal balance, how much for 35" Swamper? btate Defender Technical Discussions 0 November 15th, 2006 12:54 PM
