Dumb timing question - Defender Source
Old September 30th, 2008, 09:34 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I'm trying to get the timing right on my brother's 94 d-90. The scale on the crank is so rusty the only thing I cam make out is TDC and none of the hash marks. I believe correct timing is 6 degrees (two hash marks) BTDC. I feel dumb asking this but which way is before and which was is after? I can't read the scale. Is it left or right of tdc? Thanks.
Old September 30th, 2008, 10:11 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Right (Drivers side) is BTDC. The next large hash mark on the crank is 12 degrees, put it half way between TDC and the next large hash mark.
ATDC........TDC........ BTDC
| ......I....I... |.... I.... I... |
12.............. 0.............. 12
Old September 30th, 2008, 09:31 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
thank you
That diagram is awesome. Thank you. I guess the reason it had no power and was running hot was due to the fact that I thought it was backwards.
Old October 1st, 2008, 09:16 AM
atvsmurf
John Murphy
'90 RRC
hit the scale with a little fine sandpaper, then rub chalk into the numbers and lightly wipe the surface clean... the numbers will show up really well...
Old October 1st, 2008, 01:24 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
maybe I can duck tape a hella lamp onto my timing gun...
300 Tdi Timing Belt Question moose Defender Technical Discussions 11 January 22nd, 2008 03:58 PM
Dumb Clock Question Rob Defender Technical Discussions 0 October 21st, 2005 03:03 PM
Dumb ignition/door key question, did search first Neo Defender Technical Discussions 15 May 30th, 2005 07:10 PM
Dumb question Burke Misc. Chit-Chat 5 December 1st, 2004 08:21 AM
Really dumb shock question Neo Defender Technical Discussions 1 August 9th, 2004 01:20 PM
