Dual transfer cases - LT230 - Defender Source
Old March 22nd, 2016, 10:29 PM
oilburner's Avatar
oilburner
JL
large pile of parts
I originally dreamed this up 5+ years ago when NV4500 to LT230 adapters were few and far between, and one of my 4wheeling buddies has a Unimog, so I had serious shifter and gearing envy.
The idea was to use the reduction box out of an NP203 American transfer case, which came in all kinds of applications and bolts up to an NV4500 or just about any other american trans (4L65, 4L80, TH400, etc etc) without any custom work. There are input gears in just about every common spline from 23 spline Dodge to 27 GM, 32 GM, 31 Ford etc. So it becomes sort of like a universal adapter.
The case gives you an additional selectable gear reduction between the trans and the LT230 T-case, so you would have high, low (3.32) and super low (6.64). The best part is it gives you an extra shifter to play with.
The input gear for the LT230 transfer case was EDMed by Buck (Buckon37s) out to 32 spline GM. The output shaft was machined and re-splined in house, and the adapter plate was milled out of a great big hunk of aluminum. The only work I did not do myself was the EDM work, and plating the bolts.
The LT230 in question is a really early (1983) version from a Range Rover, LT230R 1.003 gear ratio.
The addition of the box adds 6.875" to the powertrain, but it also acts as an adapter between an American trans and the LT230. I don't think this would fit in a 90 but it fits into a 110 pretty easily. With the NV4500, the overall length from bellhousing to the LT230 mounting flange is 32.875, which is 8.3 inches longer than an R380 from a Defender application.
The gearing is kind of crazy. 5.61 1st in the NV4500 X 2 X 3.32 X 4.10 axle ratio is 152 to 1... And it's a very stout unit. But what really matters is I get another shifter!
ID:	145712   Click image for larger version
ID:	145714   Click image for larger version
JL
Old March 22nd, 2016, 10:36 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Nice!
Old March 22nd, 2016, 10:39 PM
What's it going behind ? 6b ?
Old March 22nd, 2016, 10:43 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
That is really slick JL!
That finish is incredible too!
Old March 22nd, 2016, 11:08 PM
oilburner's Avatar
oilburner
JL
large pile of parts
6BT (T = turbo)
JL
Old March 22nd, 2016, 11:12 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Originally Posted by oilburner View Post
6BT (T = turbo)
6BT with that low low will be able to climb walls
Old March 22nd, 2016, 11:41 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
You weren't kidding about the plating. Looking good!
Old March 22nd, 2016, 11:52 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Would turn 37's without an issue, I could probably assist in your acquisition of a 6bt should you decide to go down that road.
Old March 23rd, 2016, 12:07 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I'm sure 37's wouldn't be an issue!
Going new IP with bigger plungers and a bigger turbo on the OM617 for now but thanks for he offer
Old March 23rd, 2016, 06:11 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Wow, that's sweet.
One can never have too many shifters! It'll be like a 'mog with the 3x8 cascade box.
Old March 23rd, 2016, 09:21 AM
JL has had his 6bt for quite some time and already had it in a 109.
He had the 109 out @ Moab climbing slickrock etc.
What he's building now is what I want to see.
Old March 23rd, 2016, 09:33 AM
oilburner's Avatar
oilburner
JL
large pile of parts
The plating is zinc passivate, mostly for corrosion resistance...
With the 6BT the gearing is probably overkill, but, shifters!!!
JL
Old March 23rd, 2016, 09:36 AM
quit teasing post pictures of what you are putting it in
Old March 23rd, 2016, 09:43 AM
The plating is zinc chromate, mostly for corrosion resistance...
Fixed it
resistant, yes, proof, no.
Pretty damn awesome doubler box I gotta say.
Old March 23rd, 2016, 10:01 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
This work is over the top.
I am wondering if it is possible to use this in a Land Rover gearbox configuration for use with small diesel engines, like the Land Rover TDI.
So if this application were used with a 300TDI for example.
The extra length might be taken up by a stumpy R380 that would space the 300TDI in or close to the stock location.
Perhaps all you would need would be a short adapter between the stumpy and the reduction box.
I know the original goal was probably to adapt the whole assembly to a main stream gearbox and thus an easy adaptation to any number of more powerful engines, but what about a "sandwich concept" pieced into a Rover drive train?
RDavisinVA
Old March 23rd, 2016, 10:11 AM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Nice...
Old March 23rd, 2016, 01:16 PM
oilburner's Avatar
oilburner
JL
large pile of parts
I need to give credit to another guy, I just found out Tony - 16KPSI - originally ran the run of EDM'd gears input gears for Buck! He's using one in his own 110 I believe. Thanks Tony, it worked slick. He's also putting a 6BT in his 110. Obviously a smart guy.
As far as using this behind an R380, it would be tough, the idea behind the adaptation was to be able to bolt up to a standard American trans, and they use a different output arrangement than a Rover trans.
For the R380, a custom output shaft for the trans would be needed, which is a lot of work. I think the Ashcroft Underdrive is probably the best option if you want to retain stock rover stuff...
Doug - I will start a build thread eventually, right now all I have is a large pile of parts, I literally am just building all the parts one by one, nothing much to look at until I start assembling it...
JL
Old March 23rd, 2016, 08:37 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I finally have a use for this
Old March 23rd, 2016, 09:52 PM
that right there is funny
Old March 24th, 2016, 01:45 PM
cruisermatt
Matt M
Rover-less Scum, 1990 TLC
Very nice setup. The 203 is a great unit, affordable and everywhere. I'm currently setting up an NV4500/NP203 for my Cruiser, looking forwards to your crossmember and shifter designs, I'm not quite at that stage yet and could use all the inspiration I could get.
Geared Restorations - Matt
lt230, transfer case
transfer cases 1.4, 1.2, and 1.6 draaronr For Sale - Parts 9 December 13th, 2013 02:13 PM
Free: Two LT230 transfer cases in RI red64chevelle For Sale - Parts 9 June 17th, 2013 08:27 PM
dual flexalite dual electric fan setup (2500cfm) crown14 For Sale - Parts 5 May 5th, 2009 10:33 PM
transfer case . . . transfer Abrooks Defender Technical Discussions 38 October 20th, 2008 09:04 AM
Rebuilt LT230 Transfer case Bill Jansz For Sale - Parts 0 March 9th, 2004 07:00 AM
