Dual Shock Problems..help /pictures needed - Defender Source
Old January 14th, 2007, 01:19 PM
sajidd
Sajid Dadabhoy
Put on pair of rancho 99157/59 shocks as second shocks on my 110 using custom mounts.
No problem in the back..however in the front, the tyre touches the shocks when turning.
I dont think there is enough space in the front for the second pair and I may have take them off.
However on the net I have seen pictures twin shocks in the front as well. So I know it can be done.
One possible soultion is to put spaces on the tyres and move them out. I dont want to do that.
I will post pictrures tomorrow. IN the meantime I welcome any suggesstions / help / pictures / illustrations.
Pls help!
Take care
Sajidd
Old January 14th, 2007, 02:02 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Spacers is one solution. Two different dual shock setups I have used had the outside upper shock mount medial from the OEM mount. So the shock was inboard from the OEM mount and further from the tire. You didn't say whose dual shock setup you were using. You can also use the front shock mount from an airbagged rover - bolts up easily, but cutting is required on the inner wheel well.
Old January 15th, 2007, 06:37 AM
sajidd
Sajid Dadabhoy
Hi Hoosier, can you email me pictures of your set up? i will post pictures of mine later today or tomorrow so that you know the kind of set up i have on my 110. The mouns were made here locally in Pakistan sot they are not from any particular brand. The outside shocks aer mounted about 2 inch lower than the front shocks because the extended lenght of the outside (rancho shocks) are different than inside (old man emu) shocks.
thanks for responding.
Sajidd
Old January 15th, 2007, 10:24 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
http://www.eastcoastrover.com/93phase3.html
Don't know if it helps you, but there you go.
Email:
Old January 15th, 2007, 03:57 PM
sajidd
Sajid Dadabhoy
Every bit of info helps..Thanks ECR. Did you guys fit wheel spacers to make room for the outside the spring shock? Seems like i may just have to go that route..
Look forward to more solutions...
Sajid
Old January 15th, 2007, 04:51 PM
ECR's Avatar
ECR
No spacers, no turning radius issues, but then again the NAS 110s run the D130 steel wheel that has a wider offset than most rest of world Defenders.
Email:
Old January 16th, 2007, 05:18 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Sajidd- One of my dual shock mounts was from Westfield 4X4 (who I don't think do land rover anymore) and the other was MJ Lee (who still makes the dual front shock mounts). Both companies are UK. I got your email and when it thaws out a bit, I will send some photos.
problems
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
Dual Shock Mounts sajidd Defender Technical Discussions 0 November 26th, 2006 04:42 PM
A few problems - Help needed arbik Defender Technical Discussions 10 April 14th, 2005 04:54 PM
Why Dual shock set up? sflash868 Defender Technical Discussions 11 February 28th, 2005 02:34 AM
Rancho 9005 shock DBZ2009 Defender Technical Discussions 6 December 13th, 2003 10:28 AM
