Dual Optima question - Defender Source
Old August 30th, 2005, 10:22 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
When running two yellow tops in parallel should I put the positive from the engine on one battery and the negative on the other or put them both on the same battery.
Joe
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old August 30th, 2005, 11:30 PM
Technically is doesn't matter. In reality I would hook up both - and + to the same battery and run a second set of cables to the other Optima. By placing one lead on each battery you are adding an extra thing to go wrong and disable your vehicle.
Old August 31st, 2005, 07:53 PM
Troys
Troy Smith
1995 D90 SW
Joe;
John Lee at Expedition Exchnage has an excellentwrite up with photos on his site.
Troy
Dual Batteries on TDI / Optima Rugbier Defender Technical Discussions 24 November 17th, 2009 01:39 PM
Quick question, let's say you lose the rear brake line on a D90, is it dual circuit? evilfij Defender Technical Discussions 8 July 21st, 2009 08:05 AM
Dual Optima connection options btate Defender Technical Discussions 4 June 5th, 2006 06:01 AM
Why Dual shock set up? sflash868 Defender Technical Discussions 11 February 28th, 2005 02:34 AM
