Dual Battery Solenoid fried.. literally - Page 2 - Defender Source
Old March 24th, 2011, 07:50 AM
Still don't have enough to go on to say you need system x or system y.
The truck has a convenient on-board battery charger; the alternator. Let's guess that it's a 105 amp alternator. I'll take a SWAG and say that at 2000 RPM the alternator puts out about 30 amps. Your total load on the battery must exceed that for the battery to begin to drain. That's 360 watts more or less.
If all the stuff you are running is more than that you need to either split the load between two battery banks or get a bigger alternator.
If you want a spare battery for emergency starting, just keep one in the back and swap it out when you need it. Don't even bother trying to cable it up.
If you want to run your stereo and fridge and winch and not compromise the start battery you need a dual charge system.
battery
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Dual Battery jijalicious Defender Technical Discussions 22 July 12th, 2010 11:47 AM
Dual battery monitor location (Nat. Luna) Cred Defender Technical Discussions 6 May 4th, 2009 07:37 PM
Simple Dual Battery Isolator? OCD90 Defender Technical Discussions 1 April 9th, 2004 11:23 PM
