Dual Battery Problem - Defender Source
Old December 27th, 2011, 11:07 AM
Landy1
Justin Simmons
97/d90
I have a red top and yellow top dual optima system installed under my seat. It has a switch for dual batteries on, red top battery on (which I normally run), or emergency. I had the batteries checked yesterday and they tested good but low in charge and the alternator tested good as well. They are losing charge somehow though. Any thoughts?
Justin
Old December 28th, 2011, 01:13 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Optima's are AGM batteries and as such, should only loose about 1% of full charge, even if you let it sit for a whole month. Without a battery isolation kit, what happens to one, will happen to the other.
On your daily drive, are you driving (or have your engine running) at least 1/2 hour? They could be chronically getting under charged by many patterns of bad behavior. Do you shut all electrical drains down before you turn off the key, head lights, park lamps, stereo, A/C, fan/blower? Do you have a high draw stereo system? Are leaving any draws on by accident, eg. dome lights, (though the '97 has the feature to shut down the dome(s), even if you leave a door open)?
My battery typically rests at about 12.4 volts after a sit overnight. I sometimes put a charger on, it set for 2 amps, overnight just to give it a little boost. I made a (+) lead on the big fuse block under the hood, so I don't have to pull the seat every time I want to give it a trickle charge. My red top lasted for 8 years. I now use a Duralast for a 1985 BMW 524td, 850 CCA.
Old December 28th, 2011, 08:34 AM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Does Bat 2 get isolated when the truck is off? My dual battery kit isolates the aux battery when the solenoid isnt engaged to ensure I have at least one good battery.
Old December 28th, 2011, 08:43 AM
How old are your batteries? Is one battery newer than the other? Is it wired correctly? Are all the connections tight? What is connected to each battery?
Disconnect the system and use one battery at a time, maybe one is starting to fail.
Pick up a battery tender and hook it up at night or over the weekend.
battery
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Dual Battery jijalicious Defender Technical Discussions 22 July 12th, 2010 11:47 AM
Simple Dual Battery Isolator? OCD90 Defender Technical Discussions 1 April 9th, 2004 11:23 PM
Alternator/Battery problem - Repost Eric_S Defender Technical Discussions 1 January 19th, 2004 09:57 AM
