dual battery management - Defender Source
Old April 23rd, 2008, 08:43 PM
http://www.wranglernw.com/pc-6372-79...1993-1997.aspx
found this seems $$. Anyone have much insight to offer on wiring up for winching duties. Did a search but didnt really read much. Anyone running this setup?
Old April 23rd, 2008, 09:45 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
I'm not running their management system, I have the Hellroaring Battery Isolator; however, I do have the tray.
It 's a great platform for any single or dual battery setup.
Old April 24th, 2008, 10:33 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've been using a surepower isolator, but that looks interesting. How long have you had it? I'm curious about longevity.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 24th, 2008, 10:50 AM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
I have had the Hellroaring system for about 7-8 years - without any issues.
Old April 24th, 2008, 10:51 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Why do you need a tray when dual Optimas fit in a stock NAS Defender with no mods??
Email:
Old April 24th, 2008, 11:20 AM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Picture?
I am running the National Luna Split Charge system. I like it.
What makes it cool:
1 Will not discharge main battery if accessory battery goes down.
2 Charges second battery automatically
3 No manual switch to pick witch battery gets charged.
4 Alarm to let you know if battery drains too low. And you need to start the truck. Like if you are running fridge or work lights when camping.
5 You can jump start the starter battery from the aux battery with the push of a button.
6 You can connect the batteries with a with same button for more power for winching.
I bought the parts from Expedition Outfitters. I did not buy the kit to save some money, but a probably spent the difference at NAPA and gas to get there and back like 4 times. Next time I will buy the kit.
Itís kind of expensive, but $375, but worth it so far. Kinda sounds like an addvert. Sorry
http://www.nationalluna.com/DIY.htm
http://www.equipt1.com
--Benjamin Franklin
Old April 24th, 2008, 11:26 AM
ECR's Avatar
ECR
Originally Posted by mhansen
Picture?
See most of the 110 projects on our site, they usually get 2 Optimas and the fit perfectly in the stock battery box.
Email:
Old April 24th, 2008, 11:41 AM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
I'm running that system, Phil. I don't have the tray though. Yikes, I don't remember having paid that much for it!
No complaints with it after about 4-5 years. Came in handy a couple times, most recently when one of my batteries crapped out on me. I just flipped the switch and had a fresh one to get me going. Seems to give some extra cranking power in extreme cold when I flip the switch to run both at once.
8-track, gun rack, spittoon, gimbal mounted beer buoy, blah, blah, blah, blah......
Old April 24th, 2008, 12:19 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Yeah I've got dual optimas in my truck with no mods at all.
Jimmy Buffett
Old April 24th, 2008, 12:36 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
I believe they do, but for some reason I seem to remember the drivers side of the box creating a slight incline. Are all NAS defender battery boxes the same? I don't know.
However, the tray increases the mountable surface inside the box, which might allow for larger batteries, but also supplements an extra J-hook between the batteries. Although in the picture on their [WNWPP] website I only see two. Mine has three and keeps the cross bar from warping.
I always had problems with the OEM J-hooks; they kept popping out of the floor mounts allowing the batteries to slide all over the box. It was a complete disaster. Any material that seeped into the battery box acted as 60-grit sandpaper. I replaced the OEM with some generic hooks, but the problem ensued. Serendipitously, I dropped by Wrangler NW to pick up some equipment when they asked if I would like to be the guinea pig for their tray. I installed it, provided pictures with notes and my opinion.
DJ
Old April 29th, 2008, 08:44 AM
btate
Bryan Tate
d90
I went with the painless dual battery kit. Just had to replace one of the yellow top optimas, but other than that problem the system works well.
Old April 29th, 2008, 10:12 AM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
I have the TJM IBS in my D2 with dual yellow top optimas... installation was rather easy and it has worked flawlessly since I've installed it... The biggest problem though is the cost, it was quite pricey..
http://www.tjmbullbars.com/ibs.htm
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
battery
Dual battery monitor location (Nat. Luna) Cred Defender Technical Discussions 6 May 4th, 2009 07:37 PM
Dual Battery Charging RBees Defender Technical Discussions 5 January 4th, 2007 08:51 AM
Simple Dual Battery Isolator? OCD90 Defender Technical Discussions 1 April 9th, 2004 11:23 PM
