Dual battery install? - Defender Source
Old May 22nd, 2008, 07:06 AM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
I am about to try the to put dual batteries in. does anyone have pic showing how you fit them both in there.
Old May 22nd, 2008, 08:02 AM
draaronr's Avatar
draaronr
Here
LR3
Here are mine in my old 90
Old May 22nd, 2008, 09:38 AM
themaxx's Avatar
themaxx
Ade
94 ST
Hey Dana,
There are a ton of great threads on the forum in regards to the dual battery setup when you're ready to tackle this!
https://www.expeditionexchange.com/optima/DCP_2446.jpg
www.d-90.com/forum/showthread.php?t=5890
Old May 22nd, 2008, 10:08 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Another orientation..
Name:	Duals Mock-up.jpg
~Scott T.
'95 D-90 ST - AA Yellow
Old May 22nd, 2008, 01:18 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
Those battery compartments look too neat and organized.
Your making me want to upgrade mine..
Old May 22nd, 2008, 01:38 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
My only input is that two Optimas seem to fit best. I ended up adding another standard battery and they both are a pretty tight fit in that compartment. And mine also also doesn't look as sexy as Scott's.
Semper Fi!
Old May 23rd, 2008, 07:01 AM
Hammertime's Avatar
Hammertime
Dana Hammersley
what did you guys use to put under the batteries to fill the dip in the bottom of the battery box? where did you get your battery tie downs
Old May 23rd, 2008, 07:04 AM
draaronr's Avatar
draaronr
Here
LR3
I used starboard. No tiedowns. I had a terminal, and other things you can't see under the custom cover in my pic. It was so snug there was no way it was moving.
Old October 15th, 2009, 12:56 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Dual Battery Installation
After having read up on the threads on here regarding Dual Battery installation I have decided to go for it. I have a couple of accessories that I am planning to hook up shortly (fuel filter heater, front seat heaters, another set of aux lights and perhaps even a compressor in the future). I was planning on following advice on this board and hook those up to a separate fuse panel (like the Painless wiring weather resistant auxiliary fuse block part 70207). and then run that to the dual batteries. For the dual battery switch and isolator I was considering this set up from West Marine: http://www.westmarine.com/webapp/wcs...classNum=12106
Any reason this wouldn't work in a D90?
As far as securing the batteries in the seat box I was looking at something like the Kilby Dual Battery tray but I think its a bit steep at $200. Any other ideas out there? Has anybody made their own dual battery tray?
Old October 15th, 2009, 01:03 PM
http://members.shaw.ca/red90/batteries.JPG
I used 1" insulating board to fill the dip and the stock holddown.
battery
Dual battery monitor location (Nat. Luna) Cred Defender Technical Discussions 6 May 4th, 2009 07:37 PM
Dual Battery Charging RBees Defender Technical Discussions 5 January 4th, 2007 08:51 AM
Simple Dual Battery Isolator? OCD90 Defender Technical Discussions 1 April 9th, 2004 11:23 PM
