Dual Battery Charging - Defender Source
Old January 3rd, 2007, 02:17 PM
RBees
Robert Bees
1994 D90 #8
Before I set fire to something, does anyone know if it matters WHICH battery I connect the charging leads to in a dual battery setup and in which position the switch should be (1/Both/2) ? This would apply to trickle charging and fast charging.
Thanks !
Old January 3rd, 2007, 03:02 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
How is the system managed?
Old January 3rd, 2007, 08:56 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Thanks !
I set mine to dual and use the negative post of one battery and the positive post on the other battery. I don't know if it's the best but it's been working for me.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old January 4th, 2007, 06:03 AM
RBees
Robert Bees
1994 D90 #8
To be honest I don't know much about the system. It came with the truck, and according to the prior owner was a LR factory install. It has a Cole Hersee switch on the front of the battery box, but other than that I don't know....
Old January 4th, 2007, 08:31 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
http://www.pirate4x4.com/tech/billav...tery_setup.htm
This should help. Though I can't recommend mounting that switch to the dash...
Old January 4th, 2007, 08:51 AM
RBees
Robert Bees
1994 D90 #8
Thanks for the info - interesting switch location, for sure.... I guess he went for the path of least resistance..!
Happy Birthday, by the way !
battery
Dual battery monitor location (Nat. Luna) Cred Defender Technical Discussions 6 May 4th, 2009 07:37 PM
Battery Charging chris snell Defender Technical Discussions 3 November 29th, 2006 12:20 PM
Simple Dual Battery Isolator? OCD90 Defender Technical Discussions 1 April 9th, 2004 11:23 PM
