Dual battery - Page 2 - Defender Source
Old December 29th, 2010, 01:13 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Before you get carried away with all this duel battery/luna stuff I would check and see if there is a drain in the original system. All your add-on stuff maybe working fine but that doesn't mean POOP if you got a short/drain in the system. Load test the batteries by them selves and them check the out put of the alternator. If you don't find any drains/shorts in the rest of the system. You might even have a glow-plug staying lit with the car off. Just a thought before you scream "the sky is falling" on all your new electrical stuff.
Old December 29th, 2010, 01:27 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I bought a 10 farad capacitor from the stereo shop and it has a digital readout that tells you how much voltage your getting off the battery. For example on my series III, I noticed more voltage comming off the battery after I replaced the main charging cable from the alternator, so the capacitor readout is very handy actually and most start at around 15-20 bucks if you buy the cheap ones. They work for that purpose and its also good to have one for your stereo amplifier.
Robert Deniro
Old January 24th, 2011, 05:05 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Just curious if anyone has had any issues with matching two batteries of the same brand/model/age but different group sizes? I am thinking of pairing a group 31 and group 34 Die Hard Platinum batteries but know that they have dissimilar specs (CCA, reserve, etc...)
I will be running with a smart solenoid system similar to the Luna
Old January 24th, 2011, 01:43 PM
Knife90
john sabra
'94 Defender 90
i just installed the luna split system this weekend, and my impression from reading up is that the batts do not need to be matched. if they're unmatched you should use the higher CCA batt as your "main", and the lesser as your "aux".
battery
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Dual Battery jijalicious Defender Technical Discussions 22 July 12th, 2010 11:47 AM
Dual battery monitor location (Nat. Luna) Cred Defender Technical Discussions 6 May 4th, 2009 07:37 PM
Simple Dual Battery Isolator? OCD90 Defender Technical Discussions 1 April 9th, 2004 11:23 PM
