Dual Battery - Defender Source
Old July 7th, 2010, 08:55 AM
jijalicious
Jiman Khosravan
'94 D90
Question Dual Battery
So I'm been searching the forum for a dual battery setup...
And I'm even more confused as to what to get.
The goal: not to get stranded with dead battery.
1) I am installng a camera system in the car which will record movement in the car. Thus it will need a power source when the car is sitting and could possible drain the battery.
2) I tend to leave lights on.
3) I wash the car often and use the stereo when the car is off so that uses battery too.
4) so on and so on...
From Painless power.. I saw P/N 40120: Digital Power Manager which seems like it should the trick when having dual batteries.
But everyone talks about P/N 40102: 250 Amp Dual Battery Current Control System
or even http://www.powerstream.com/battery-isolator.htm
So I'm confused BEEEEEG TIME as to the total parts/kits I need to make sure I don't get stranded by simply blasting the stereo in the middle of the forest while BBQing the trout I just caught.
Thanks gents ,
~Jij
Old July 7th, 2010, 12:19 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I bought this Dual Battery Kit: http://bluesea.com/category/2/productline/overview/329
It comes with an Automatic Charging Relay and switch. You can combine the batteries if one runs dead, run them in parallel or turn them off for storage. I have yet to install it though.
Which camera did you get? Let me know how the install and usage of that goes. I'm curious.
Old July 7th, 2010, 12:31 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
At the recommendation of Gustavo (Rugbier) I purchased this system and like it a lot so far...although I have only had installed for a week or so.
http://cgi.ebay.com/VORTEX-12V-DUAL-...ht_5132wt_1137
I tossed the cables and connectors for some heavier duty units and used relays like these
http://www.hifisoundconnection.com/S...d/0/rid/123284
This system allows you to have a house and accessory battery and isolates them so you won't drain the house battery with peripherals...but is smart enough to pull power from accessory battery to start the truck if needed. Also has a manual override in case you want to just drain both batteries (ie winching out of a tight spot!)
Old July 7th, 2010, 01:00 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Looks relatively easy to install - am I right? As in, can a newb-electrical person do it without completely screwing it up?
-Ren Ching
Old July 8th, 2010, 12:34 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
I installed the painless 40102 a few weeks ago with two yellow optimas...and am very happy. Have been meaning to take some pics...
Old July 8th, 2010, 07:20 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I've installed a National Luna split charge, which looks vveeerrrryyy similar to the Vortex, for a D90 with a whomping stereo. We had an issue with it blowing the 50amp in line fuse 2x. After re-reading the installation instructions, it's possible that we had not pushed the right sequence of buttons on the split charge controller and given the batteries time to equalise as recommended, but their solution was to just up the amperage of the fuse!
So, it sounds like you need to have a dedicated start battery and a 'normal' operations battery for the camera and stereo as well a scar functions, so a split charge is the way to go. Another option could be a marine battery switch. I think simple is better.
Check out Overland Journal. They did a comparison of split charge systems last year.
Still lovin' the Rover?
Email is
Same place, new dogs.
Old July 8th, 2010, 09:35 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
It was very easy and straight forward. I took more time deciding where I would mount things than anything else...
Old July 8th, 2010, 10:22 AM
I used the Wrangler NW parts system in two of my trucks.
Old July 8th, 2010, 12:25 PM
jijalicious
Jiman Khosravan
'94 D90
Vortex and National Luna... I feel that's the way to go...
But NL is in SA??? Any resellers in the US?
Trevor.. LOVE the 90. Took out the back, sides and top of the doors.
No AC is a little rough in 102 degree weather... but she is a BEAUTY and worth every drop of sweat!
Old July 8th, 2010, 01:46 PM
Chaucer
Will
93 110 | 97 90
I went with Hellroaring Technologies dual battery isolator/combiner with the remote module for switching between auto/off/on. Solid state, works great, excellent customer service.
Old July 8th, 2010, 03:25 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
I took 4-5 hours for me to install mine. I can send you a list of what you need if you go with the painless.
But I found out there are two different camps:
1 - Put the accessory load on the 2nd battery
2 - Put the accessory load on the Starter battery
Painless goes with option 2. There are advantages to both.
The one thing I would think hard about is the batteries. Many people "mix" batteries, but according to Optima and other battery cos, you want batteries of the EXACT same type and age. You should not mix a red for starting and the yellow for accessories. I went with two yellow..
Dave
Old July 12th, 2010, 07:30 AM
jijalicious
Jiman Khosravan
'94 D90
Does anyone know how much the Vortex goes for? MSRP? and where I can purchase one?
Old July 12th, 2010, 07:50 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
where I got mine...
After checkout had the system in about 3 days
Old July 12th, 2010, 08:26 AM
National Luna is the clear choice.
I have a painless system with dual yellowtops. it has been very reliable, but the National Luna is better, and if I had known then about it, would have gone that route.
Old July 12th, 2010, 09:45 AM
jijalicious
Jiman Khosravan
'94 D90
Jeff... right.. but what is the normal $? and who sells them besdies that ebay member? I could bet $400 and win.. but then someone might tell me it costs $149 normally.
Mark... I haven't been able to find a vendor or a price either. :/
~Jiman
Old July 12th, 2010, 10:17 AM
Rugbier's Avatar
Rugbier
Gustavo
Jiman,
There is a phone number ( 1-800-609-9457 ) for the Vendor on ebay, call him, I've got mine for 142.50 shipped ( outside ebay ) and got it in 2 days .
The best part it is an IRONMAN, that sells for many many more dollars elsewhere.
Gustavo
NO SIGNATURE
Old July 12th, 2010, 10:27 AM
for national luna, you can go to Equipt1.com or Adventure trailer.
Old July 12th, 2010, 10:48 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I opted for a single battery and installed a monster DieHard Platinum PM-1. I built a custom SS bracket and installed a Blue Sea Systems fuse block and MAXI fuse.
Install pictures here:
http://www.flickr.com/photos/defende...7624314668149/
Old July 12th, 2010, 11:07 AM
jijalicious
Jiman Khosravan
'94 D90
Thanks Gustavo.. Called him and went ahead and purchased it.
National Luna is $375?! Little much for me. Hopefully the Vortex will hold out as good as the NL.
Now, off to Costco to buy 2 identicall batteries. Expenses.. expenses.. expenses.
Old July 12th, 2010, 11:25 AM
Great job documenting Chris! Looks good now. I have a Blue Sea terminal in mine as well, but I think I need a larger one for all my gadgets.
Where did you get the maxi-fuse terminal?
battery
Dual battery monitor location (Nat. Luna) Cred Defender Technical Discussions 6 May 4th, 2009 07:37 PM
Dual Battery Charging RBees Defender Technical Discussions 5 January 4th, 2007 08:51 AM
Simple Dual Battery Isolator? OCD90 Defender Technical Discussions 1 April 9th, 2004 11:23 PM
