Dual Battery - Page 2 - Defender Source
Old July 12th, 2010, 11:32 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Originally Posted by Overlander View Post
Great job documenting Chris! Looks good now. I have a Blue Sea terminal in mine as well, but I think I need a larger one for all my gadgets.
Where did you get the maxi-fuse terminal?
I got the MAXI Fuse from Defender.com (LOL). I also bought the terminal from them as well, along with all of the cabling and lugs.
For the cable, I used Ancor marine grade cable, 2AWG for the winch and 4AWG for the terminal. The Ancor stuff is expensive but worth it. Each strand within the cable is solder-coated for corrosion resistance. I also noticed that the Ancor cable was more flexible than the stuff from NAPA. The Ancor lugs are also tin-coated.
I learned how to solder battery terminal lugs by watching this video:
Old July 12th, 2010, 11:39 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Not to speak for Chris but I believe you can pick up a maxi-fuse terminal at a lot of auto parts stores (I have seen them at my local Pep Boys). I don't have any photos handy but will post a few after I take them but I went with circuit breakers in lieu of fuses.
Something like these...I believe they are available in a variety of amperages ranging from 50 up to 300 amps. I currently have a 100 amp breaker on my house battery and a 50 amp on the accessory battery.
http://www.amazon.com/Stinger-SGP901.../dp/B001TH8O8I
Old July 12th, 2010, 11:47 AM
Rugbier's Avatar
Rugbier
Gustavo
I was going to install mine on SHrek ..but ..
Anyhow, Marine Circuit Breakers is a great way to go, and while there add a Fuse Block so all your peripherals are neatly mounted to the block .
You can also have the block fused ( individually or get a straight connecting block and fuse the entire block )
NO SIGNATURE
battery
Dual battery monitor location (Nat. Luna) Cred Defender Technical Discussions 6 May 4th, 2009 07:37 PM
Dual Battery Charging RBees Defender Technical Discussions 5 January 4th, 2007 08:51 AM
Simple Dual Battery Isolator? OCD90 Defender Technical Discussions 1 April 9th, 2004 11:23 PM
