Dual Batteries on TDI / Optima - Defender Source
Old November 16th, 2009, 02:14 PM
Rugbier's Avatar
Rugbier
Gustavo
Is anyone running dual Batteries on a TDI?
if so, is anyone running Dual Optimas on it?
NO SIGNATURE
Old November 16th, 2009, 02:35 PM
I have dual Exide Orbital. Basically the same as Optimas. Search, there are thread on this.
Old November 16th, 2009, 02:41 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
yes and yes (red-tops)
Old November 16th, 2009, 02:43 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
yep. One red top and one big blue top for the house battery. Also have a hell roaring isolator.
What are you thinking?
Old November 16th, 2009, 03:12 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Yes and odyssey.
Old November 16th, 2009, 03:17 PM
Best4x4's Avatar
Best4x4
Kelly Graham
P38
national luna/ironman and 2 odysseys
Old November 16th, 2009, 03:22 PM
Rugbier's Avatar
Rugbier
Gustavo
I liked my set up ( on the 90 ) of Wrangler Ind . isolator with Yello and blue top
So before I do it I was looking for input.
NO SIGNATURE
Old November 16th, 2009, 03:29 PM
gustavo what are you running that you need dual batteries? does it power your camp setup? I've always wanted duals too but always managed to get by with just one.
Old November 16th, 2009, 03:34 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I've got dual yellow optimas.
Old November 16th, 2009, 03:37 PM
Seems like most people run one red (starter) and one yellow (accessories). What's the advantage to two yellows?
Old November 16th, 2009, 03:38 PM
Rugbier's Avatar
Rugbier
Gustavo
Dave,
Yes, will power the fridge in the trailer, plus ( don't laugh ) I am thinking to take a smaill tv for when we are camping *LOL*
NO SIGNATURE
Old November 16th, 2009, 03:44 PM
A small TV? Can't live with out your Oprah?
Old November 16th, 2009, 04:17 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
"Seems like most people run one red (starter) and one yellow (accessories). What's the advantage to two yellows?"
Seems to work better for me. Have the same setup on my D110. I have never used blue tops, but I've had dual reds and one red-one yellow. Identical yellows seem to last longer in my hands. Also, they look better in my yellow 110
Old November 16th, 2009, 04:32 PM
I have dual yellow tops. Everything I've read on dual battery systems say to run the same type of batteries together, and they should be of similar age.
Old November 16th, 2009, 05:35 PM
This is true unless you have an isolator... On my ST, I run two yellow tops, tied together. In my SW, I have the Wrangler NW system with a Redtop for starting and normal operations and a yellow top for the fridge, winch and lights.
Years ago, I ran a used Red and the Yellow that came with the truck, tied together and they lasted for over 3 years, at the time, I did not know any better and nothing bad happened.
Old November 16th, 2009, 07:05 PM
Rugbier's Avatar
Rugbier
Gustavo
Get it straight ..it is Jerry Springer *LOL*
NO SIGNATURE
Old November 16th, 2009, 07:48 PM
Gustavo has done great things with this truck since I handed him the keys. What are you guys running that requires a second battery ? Tdi's only need starting amps and are load free. Gustavo's truck has a 1300w inverter. I went 2000w for the 130 but still have no plans for a second battery. School me. My offshore fishing boat has two 8d's and a group 40. I thought I understood 12v amp usage and am not getting the need????
Old November 16th, 2009, 08:07 PM
D90user's Avatar
D90user
steve
My main need is camping. When running the fridge when it is hot out it drains quick. When I can get solar that is great but when you cant...
I also changed all interior lights to LED and that helped for hanging out at night.
Old November 16th, 2009, 08:34 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Steve, did you fit the LED's in the existing lamp housings? If so, what did you get that fits in there?
I'm leaning towards getting the Dual Circuit System from West Marine: Add-a-Battery Dual Circuit System
Old November 16th, 2009, 09:59 PM
D90user's Avatar
D90user
steve
Yep. stock housings. Look at superbrightleds.com, just take yours out and it will be obvious.
I just remembered I was supposed to take pictures of the fuel filter for you... will do tomorrow!
tdi
Dual Optima connection options btate Defender Technical Discussions 4 June 5th, 2006 06:01 AM
Dual Optima question Joe P Defender Technical Discussions 2 August 31st, 2005 07:53 PM
Optima batteries - whats what? paulb Defender Technical Discussions 4 August 16th, 2004 10:14 PM
Batteries dead jorge Defender Technical Discussions 13 October 28th, 2003 03:28 PM
