DS Running light? - Defender Source
Old June 27th, 2004, 01:53 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
DS Running light?
Let me preface this by stating I have just started to work on the 90 and have no electrical experience what so ever!
So, it's a gorgous sunny day in Chi town, I finally get have some time to work on the truck. I planned on putting Hella H4 lamps in my rig. So I start by removing the all the running lights and tried to get the black plastic headlamp covers off. The running lights came off easily, but I the last two screws holding the cover on the front of the wings are seized in place. No big deal, I decided to get some PB and soak them. Reassemble the lights get everything back together and test the lights. The top running light doesn't work. Bulb is OK. Headlight works as does the directional. The wire was taught to the top running light. I had to remove the horn to actually get the connection back in place.
Do I need to get a test light to see if I accidentally pulled a wire? I would be really pissed if I had to have any wiring done...
And while I'm venting, why the hell is it so involved to replace a the front lamps? Damn!
EwS
Old June 27th, 2004, 07:55 PM
You should be able to see if the wires are connected by opening the hood and looking under the wing at the back of the headlight. If you don't have one then get a multi Meter! Well worth the investment when you own a Land Rover.
EwS
Hey it's a rover Its got its quirks.
ht
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
LED running light bulbs JBfoot Defender Technical Discussions 23 April 12th, 2008 05:53 PM
Light disaster! rustydefender Defender Technical Discussions 11 December 30th, 2005 03:34 PM
Dash, Running & Head light PROBLEM ! Weldon Defender Technical Discussions 5 November 9th, 2005 02:04 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
