Dropping my oil pan... - Defender Source
Old May 18th, 2006, 09:12 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
My oil pan is leaking and I was wondering if I should use a LR gasket or use the "Right stuff" to make the seal? Also, while the pan is down, what other if any maintenance should i perform.. oil pickup??? Thanks.
Old May 18th, 2006, 09:20 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Skip the gasket. The factory stopped using gaskets quite some time ago as they tend to leak.
Use a quality RTV (black or grey).
Drop the pan, let everything drip dry for as long as possible. The clean the pan and the block edge and use a thin coat of RTV on the pan as well as thin coat on the block itself (smear it arund, not a bead out of the tube) and then join them... no more leaks.
Other than taking a look and making sure the pick up screen is clean there is little maint. to do in there.
Email:
Old May 18th, 2006, 10:30 PM
Abrooks's Avatar
Abrooks
Tony Brooks
It's about an easy job as you'll find, right stuff works very well. If you have access to a parts washer, it'll make cleaning the pan up that much easier, if not carb cleaner works just as well.
Old May 18th, 2006, 11:00 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I dig your avatar. Very nice!
Right stuff works great.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 19th, 2006, 06:18 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
right stuff is the shit. The excess that invairiably gets squeezed out will not wind up falling off and getting sucked up into the oil pick up as will happen with any silicone based product. I've seen many oil pickups full of little silicone boogers.
Matt Browne
Old May 19th, 2006, 10:26 AM
ECR's Avatar
ECR
Ever try taking the oil pan off again after you have sealed it with that product?
It ain't fun.
Email:
Old May 19th, 2006, 12:01 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
sounds great thanks evryone. as for that avatar.. the next few moments were not so sweet. every crawled out of a land rover on it's side?? one more thing about the oil pan, are the bolts different lengths like the water pump and need to be in specific places, or can i just throw em in a bucket?
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
Oil pan drain bolt size?? mspell Defender Technical Discussions 1 October 2nd, 2004 12:09 PM
