Dropping fuel tank (D90 NAS) - Defender Source
Old April 18th, 2017, 03:46 PM
shidinger's Avatar
shidinger
97 Arles D90
Hello all
Does anyone know if it is possible/safe to drop the fuel tank (by removing the sway bar, and other bolts on the skid plate) WITHOUT removing fuel lines or depressurizing the system?
I need to replace a cracked return hose.
Old April 18th, 2017, 03:54 PM
ron's Avatar
ron
Ron
1995 110 Beach Runner
really best and easiest is to drop the tank...
good luck with your search
Old April 18th, 2017, 04:21 PM
shidinger's Avatar
shidinger
97 Arles D90
thanks for the response Ron. What i'm wondering is if I can just unbolt the sway bar and plates and lower the tank down? Or, do i have to depressurize the fuel system and disconnect the lines first?
Old April 18th, 2017, 04:51 PM
ron's Avatar
ron
Ron
No pressure.... you will disconnect the fill hose ,overflow hose , fuel pump plug then the fuel lines in and out.... it really is the best way to do the repair...
Make sure to spray PB blaster on all the bolts...
Old April 18th, 2017, 06:48 PM
Try run the tank to empty first to keep it light, but there are no issues doing as you describe.
Originally Posted by pendy
I'm here for the D's
Old April 18th, 2017, 06:51 PM
shidinger's Avatar
shidinger
97 Arles D90
good advice. i'll run the tank down. drench the bolts with PB blaster. and drop it down.
thanks.
90, d90, fuel, fuel tank, nas
1997 NAS D90 soft top Beluga Black 86K hlamar For Sale - Vehicles 30 July 24th, 2013 11:11 AM
Rover Accessories D90 transfer fuel tank cdb Defender Technical Discussions 20 June 21st, 2011 05:01 PM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
How to get d--- fuel pump housing back in NAS tank? Chris Cox Defender Technical Discussions 3 October 29th, 2004 09:58 AM
Fuel lines for NAS D90 with 300tdi? Chris Cox Defender Technical Discussions 3 December 5th, 2003 04:20 PM
