Dropped cylinder wall? - Defender Source
Old February 8th, 2010, 10:08 PM
jetmech's Avatar
jetmech
Dave McHenry
1984 Landrover 90 CSW
What are the symptoms of a dropped cylinder wall on a 3.9EFI?
Old February 8th, 2010, 10:45 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
internal coolant leak...
1) losing coolant w/ no visible sign of where its going
2) white smoke at tail pipe
3) sweet smell at tailpipe
4) Coolant mixing with oil -- drain you oil.. capture the beginning of the stream into a clear container... and see how it looks, the coolant will separate onto the bottom.
5) pull a spark plug, look to see if it looks 'steam cleaned' compared to other ones
6) misfires on a particular cylinder
7) erratic idle
Another test I learned was to get a small piece of paper, roll it up, and stick it into the spark plug hole and pull it out and see if there is any coolant on it..
Almost all of those can be a sign of a leaking head gasket as well.... so other than a complete tear down, the only way I know to see as slipped liner is by pulling the oil pan... I've heard though, that sometimes a slipped liner is only visible when the engine is hot... so some mechanics get the engine warmed up, then drain the oil and drop the pan to see if it's slipped..
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old February 9th, 2010, 10:07 AM
And when you pull the headgasket look for a second ring sort of an impression when the liner is where it slipped up and down and hit the gasket.
Old February 9th, 2010, 04:25 PM
jetmech's Avatar
jetmech
Dave McHenry
Has any tried to use a borescope to inspect the linners? I'm not sure I have this problem yet. I can't get any heat and the engine temp is extreamly low.
Jetmech
Old February 11th, 2010, 12:15 AM
CDeWan
Clay DeWan
5.3L beastie
Did you try a compression check of the suspected cylinder?
Old February 11th, 2010, 08:27 AM
jetmech's Avatar
jetmech
Dave McHenry
it checked good last night.
Old February 11th, 2010, 09:45 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would get a block tester kit (got mine at NAPA, about $50). It will check for exhaust gases in the coolant and is incredibly easy to perform. All you will need to do is basically put it on your coolant resevoir and fill the tube with liquid. Takes just a minute and I think is vital for any roverites garage...
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
What do I need to know about rebuilt cylinder heads (non-LR) loykd Defender Technical Discussions 2 October 18th, 2004 10:36 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
Fault Code Misfire on #6 cylinder dbwitt Defender Technical Discussions 2 February 16th, 2004 10:30 PM
