Drop Arm Ball Joint - signs of wear - Defender Source
Old August 24th, 2011, 01:56 PM
bjf's Avatar
bjf
barry f
94 ST #395
What are the signs to look out for when the ball joint wears out. My boot is ripped and my steering clunks at times when I turn the wheel (not moving). It has been torn for a long time. My steering box doesn't leak so I was just wondering what makes people actually replace the ball joint. Can you feel the wear?
Old August 24th, 2011, 05:14 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
On mine I had the dreaded death wobble; rebuilt the drop arm, replaced some worn out bushings on the front radius arms and the wobble was gone.
Todd
'95 D90 #2206
'66 109" P/U
Old August 24th, 2011, 05:15 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah I had a wobble but I replaced the steering stabilizer and that fixed it
Old August 24th, 2011, 07:06 PM
That's a band aide if your drop arm is making noise it needs attention think how much fun it would be if it failed. Rebuilding it helped my defender but it really needs a swivel rebuild.
Old August 24th, 2011, 07:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
Well I am not sure where the clunk is coming from but I am assuming it is the drop arm. Does it really fail or just have play?
Old August 24th, 2011, 07:31 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
You can have somebody turn the steering wheel while you grasp the ball joint in your hand to feel for play. It's easy to replace the torn boot. Just pop the joint and Bob's your uncle. I used a boot from a dead tie rod end I had lying around.
John Karlsson
Hope Valley, RI
Old August 24th, 2011, 07:34 PM
bjf's Avatar
bjf
barry f
94 ST #395
well something is clunking at times when i turn the wheel and the truck is tanding still so I thought maybe it was this. Been torn for awhile
Old August 24th, 2011, 08:20 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
could also be your CV, does it pull to one side all of a sudden
3rd low and BOOT IT
Old August 24th, 2011, 08:54 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Jack up one side, grab the wheel and rock it. It will be evident if there is a warn joint and where it is if it's in the linkage.
Old August 24th, 2011, 09:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
No pulling to one side. I need to look closer. Been too lazy to jack car up.
Old August 24th, 2011, 10:18 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Do a search pitman arm or drop arm. Mine was really worn, the ball freely moved in the joint. I went ahead and replaced the other 3 ball joints too, what a difference.
http://www.defendersource.com/forum/...3&postcount=12
Old August 25th, 2011, 08:13 AM
kevkon's Avatar
kevkon
kevin
Just take it to any garage and have put on a lift. It will be obvious if there is a bad joint.
Old August 25th, 2011, 10:06 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Barry, FYI, pulling that thing is a bitch. I just recently replaced mine along with all other tie rods. I actually had to cut slices in to the drop arm to remove it. Decided not to apply heat for fear of dmaging seals int he steering box.
Old August 25th, 2011, 10:22 AM
bjf's Avatar
bjf
barry f
94 ST #395
I have heard of people doing it in place.
Old August 25th, 2011, 10:56 AM
bjf's Avatar
bjf
barry f
94 ST #395
This is my drop arm. Looks awesome.
Old August 25th, 2011, 03:50 PM
Yup its time.
Old August 25th, 2011, 07:02 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Again, here's some helpful links.
http://forums.lr4x4.com/index.php?showtopic=14338
http://www.reedx.net/landrover/maint...nkbj/index.htm
BE SURE TO DRILL, TAP & INSTALL A GREASE ZIRK ON THE BOTTOM CAP UNDER THE CIRCLE CLIP !!
Old August 25th, 2011, 08:37 PM
AB has em on special.
Old August 25th, 2011, 08:46 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Be lame like me and replace the whole drop arm - I gave up trying to get the thing apart. 90 bucks from Rovahfarm.
-Ren Ching
Old August 25th, 2011, 11:29 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I've read on this forum that getting the arm off the stearing box can be really tough too. Some guys even resort to cutting it off. Then there's the problem of getting the new arm to seat properly. A choice of poison is at hand !
D 110 steering drop arm ball joint kit Francois For Sale - Parts 0 July 4th, 2011 08:43 PM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Rear A arm ball joint DesertRat Defender Technical Discussions 9 November 27th, 2010 04:42 PM
WTB: D-90 Cross rod end, steering drop arm, ball joint kit Blakesrover Wanted 1 October 1st, 2009 09:40 AM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
