Drop Arm Ball Joint - signs of wear - Page 3 - Defender Source
Old August 27th, 2011, 11:34 AM
dchapman
Daniel Chapman
1999 D1
Originally Posted by bjf View Post
Can I rent the correct puller?
Yes.
Old August 27th, 2011, 11:45 AM
bjf's Avatar
bjf
barry f
94 ST #395
Gustavo
Find me all the tie rod ends on the lucky 8 site.
Old August 27th, 2011, 11:48 AM
Rugbier's Avatar
Rugbier
Gustavo
Gustavo
Do I look like your BIATCH?
Don't be a lazy MoFo ,
Seriously, call Justin, he'll get it for you the easy way, I've got mine through him with the HD steering components ( and all greasable nipples on them )
NO SIGNATURE
Old August 27th, 2011, 11:52 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Originally Posted by dchapman View Post
That little rubber seal in the bottom of the box loves it when you use heat from a torch.
That's why it helps to have the right torch, apply heat quickly and in the right spot, and know what you are doing.
Old August 27th, 2011, 11:53 AM
Rugbier's Avatar
Rugbier
Gustavo
Left hand thread
http://www.lucky8llc.com/Products.aspx?ProductID=6116
Right Hand Thread
http://www.lucky8llc.com/Products.aspx?ProductID=6104
Non greasable
LH
http://www.lucky8llc.com/Products.aspx?ProductID=6107
RH
http://www.lucky8llc.com/Products.aspx?ProductID=6095
NO SIGNATURE
Old August 27th, 2011, 12:10 PM
dchapman
Daniel Chapman
1999 D1
Those QH joints, like the Lemforder joints, are not worth the baggy they put them in. They'll be toast in under 10,000 miles.
Old August 27th, 2011, 12:11 PM
bjf's Avatar
bjf
barry f
94 ST #395
Would I want the greasable ones? Seriously 10 bucks? Is this a joke or is the non genuine pure trash? The envelope will cost more
Old August 27th, 2011, 12:36 PM
Rugbier's Avatar
Rugbier
Gustavo
Not sure what the better ones cost, Equipe / QT tends to include the HD greasable ones
so, call him
NO SIGNATURE
Old August 27th, 2011, 03:13 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Thought Lemforder was OEM?
Old August 27th, 2011, 04:34 PM
dchapman
Daniel Chapman
1999 D1
No. Huge difference. I think I have a pic, I'll look around.
Old September 4th, 2011, 10:53 AM
bjf's Avatar
bjf
barry f
94 ST #395
Got the new arm. Should I grease the splints before installing the new one?
Old September 5th, 2011, 12:03 PM
bjf's Avatar
bjf
barry f
94 ST #395
Just took care of it. Surprisingly the hardest part was getting the steering stabilizer side off.
Question- is the arm on far enough. I tightened as much as I could but I see splints showing
ID:	41662   Click image for larger version
Old September 5th, 2011, 05:02 PM
Tighten it to spec and you should be ok.
Originally Posted by pendy
I'm here for the D's
Old September 5th, 2011, 05:03 PM
bjf's Avatar
bjf
barry f
94 ST #395
Ha spec like I have a torque wrench
Old September 5th, 2011, 05:07 PM
Buy one!
Old September 5th, 2011, 05:34 PM
kevkon's Avatar
kevkon
kevin
There's rust!
Better take it all apart and get all new front steering and suspension parts
Old September 5th, 2011, 05:41 PM
bjf's Avatar
bjf
barry f
94 ST #395
I have already thought that. Might bu new and put it in a plastic bag so it doesnt get wet
Old September 6th, 2011, 01:04 PM
bjf's Avatar
bjf
barry f
94 ST #395
Turns out this wasn't the cause of my steering noise anyway. It was the shredded power steering belt. Oh well
Old January 28th, 2012, 12:59 AM
tdi-rick's Avatar
tdi-rick
Rick
'98 130CC
FWIW Lemförder do make the OEM TRE, but it's obviously different (shallower ??) to their aftermarket offering.
(yeah, I've dug an oldie up)
D 110 steering drop arm ball joint kit Francois For Sale - Parts 0 July 4th, 2011 08:43 PM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Rear A arm ball joint DesertRat Defender Technical Discussions 9 November 27th, 2010 04:42 PM
WTB: D-90 Cross rod end, steering drop arm, ball joint kit Blakesrover Wanted 1 October 1st, 2009 09:40 AM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
