Drop arm! - Defender Source
Old July 14th, 2005, 11:32 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Drop arm!
I just installed a new steering box and it's time to install the drop arm so I can but the front links together. Are there any tricks to install the drop arm; is there a special tool I should buy/rent?
Old July 14th, 2005, 11:33 PM
Ah no. Getting them off is tough though.
Old July 15th, 2005, 09:23 AM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
stock box?
Old July 15th, 2005, 12:35 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You don't need any tools to put it on, but if you need to get one off, go to Kragen and rent a pitman puller. Should be free and helps a lot. Other than that, piece of cake.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 15th, 2005, 12:44 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
I have the puller and I took the drop arm off the old box w/o a problem, but trying to put the arm back on the new box and I'm having hard time with that.
Yes Tis, a stock box.
Old July 15th, 2005, 01:01 PM
redrover
Guest
Posts: n/a
Yousef, what kind of trouble? I put a new arm on a few yrs back and the paint on the splines made starting it on a little hard. Are the splines the same? JP
Old July 15th, 2005, 01:49 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
I'm sure you are aware that there are grooves on the steering shaft and on the pitman arm... and every 1/4 turn has a "key".
Maybe it's not aligned correctly.
I've attached a pic of my setup and you can barely see the key or notch on steering shaft. BTW, I run a D90 pitman arm on my Disco.
John C.
Old July 15th, 2005, 02:32 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I am not sure why it would be hard, unless something is odd somehow. John is right, there are keys. When I put the Ford Pitman arm on mine I had to machine 4 notches to have it accept the thread, but stock to stock should be very easy.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old July 19th, 2005, 05:47 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Ok, it's in. Here comes the next stupid question. How do you bleed the system? Would brake bleeder do the job?
Old July 19th, 2005, 09:27 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Just get in, fill it up, turn the wheel all over the place, fill up again, then have a beer. It's been my experience that the steering self bleeds.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
WTB: D-90 Cross rod end, steering drop arm, ball joint kit Blakesrover Wanted 1 October 1st, 2009 09:40 AM
Discovery I drop arm on D90 box?? nikojo Defender Technical Discussions 1 March 20th, 2009 12:11 AM
Drag link end @ steering drop arm Uncle Douglas Wanted 3 August 10th, 2008 11:14 PM
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
Steering drop arm kellymoe Defender Technical Discussions 12 November 7th, 2004 02:07 PM
