Driving Lights/ Hi Beam Install - Defender Source
Old April 4th, 2011, 12:33 AM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Hey All
Searched but nothing close.
So my set-up uses HIDs as my mains ( & hence have no hi beam--- awesome visibility, but...), also have a bunch of auxiliaries on my roof rack, but I'd like to mount/install lights I can use to flash (hi beams).
I have an A-bar w/ winch. Over the years I've been told to drill (hell no), to look for clamps, to drill the bumper proper, etc...., but nada tht didn't seem to invite more rust or other issues.
Hence I thought I'd finally put it up here to see what you experts might have come up with or can suggest.
Thanks in advance.
AL
1994 Silver DEFENDER 90 NAS SW
Old April 4th, 2011, 02:08 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
There are a number of options...
1. Replace your HIDs with BiXenon ones
2. I thought all the A-Bars came with mounting tabs...maybe look for one that has them
3. Clamps (this is what I did on my factory brush guard)
4. There is a Light Bar available that mounts to the bumper mounting bolts
I personally used clamps because I wanted to use the factory brush guard but wanted them to hang like the Camel Trophy trucks
Old April 4th, 2011, 02:43 AM
Sorry, you are using your mains as high beams? Everyone must love being blinded by you.
Old April 4th, 2011, 03:05 AM
TS888's Avatar
TS888
Tony Sims
1984 110
John, I think what he's saying is he has HIDs and doesn't bother with high beams. I can understand that, I had a 5 series BMW with factory HIDs, and both the halogen high beams and the fog lamps were useless, you couldn't even tell the fog lamps were on. When I wanted more distance vision for back roads I just thumbed the little headlamp adjusting dial on the dash up a few degrees.
Why not clamps? If the finish on your A bar is good, then clamps shouldn't invite rust. Check out some of these nice aluminum ones. I used a small pair of these as mounts for my hi-lift on the rack on my RRC.
Bar Clamps at Summit
Tony
1984 110 "Smokey" (sold)
Old April 4th, 2011, 10:19 AM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Tony, spot on
John, HIDs don't have hi beams
I 'll check the clamp solution as it appears to be the best option.
Does anyone have a light (that could be used as a Hi beam) clamp set up on their A-bar or similar that wouldn't mind sending a link for the manufacturer or dealer? Pic maybe?
Thx guys
Old April 4th, 2011, 10:37 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
When you are doing the work I would upgrade new harness using a relay (Hella is fine).
If you have bought your HID kit, good luck with the system.
Piaa makes a Mechanical hid kit basically there is a cap that moves when you click to high beam. Last month PIAA was supposed to come out with an even more advaced system for high and low. Basically you are looking at about $350-400 for the sytem. But remember Piaa's ballast is guaranteed for life and the bulbs for 2 years...
these kits are not avialable in the USA.
these guys are on the board here http://www.piaacanada.com/hid/
these guys are also helpful http://www.nengun.com/
Nengun is in Japan, they where the ones that mentioned the latest version to me.
Here are some mounts as well http://www.shopatron.com/products/ca....25320.0.0.0.0
Old April 4th, 2011, 11:58 AM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Awesome, got it. My HIDs are Piaas from around '03 so I'm sure technology has changed a bunch. Hopefully these will solve my nagging problem since I upgraded to the HIDs 8ya.
Old April 4th, 2011, 12:45 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Just to add another option:
I just switched to truck-a-lite LEDs
1. Have high beams
2. doesnt need a new harness
3. 50,000 hour life
4. extremely focused
5. waterproof
6. shock resistance - military grade
Old April 4th, 2011, 05:49 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
1. Have high beams
3. 50,000 hour life
5. waterproof
Do you mean Truck-Lite?
What did you use to have?
What is the beam spread like?
I have been thinking of getting these, but I would like to see for myself how comparable they are to halogens.
Old April 4th, 2011, 06:13 PM
97-D90-736
Nick Vogel
Sorry, yes there are Tuck Lite
The beam spread is great. Wide at the front of the truck, narrowing to a straight line on the horizon at 75 feet. They are super clear but not Fast and Furious anoying bright.
I had the worst sealed wagners.
A buddy with a 99 H1 Hummer had a really pricey set of HID's in his truck. Even though his might be slightly brighter, the focus on mine were 10 times better.
Old April 4th, 2011, 10:18 PM
kevkon's Avatar
kevkon
kevin
Thanks, that's good to know.
Old April 4th, 2011, 10:24 PM
tjfslaughter
thomas
Burbon
Can you post a pic of them on the truck. They are great lights but the profile of them would make the front of the truck look different.
Old April 5th, 2011, 12:26 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
2nd this request. Like kevkon, I am interested in their performance as well. I am assuming you bought one like these: http://www.discountfleetsupply.com/tlc27250c-p.html
Old April 5th, 2011, 12:40 AM
bjf's Avatar
bjf
barry f
94 ST #395
Some pics of ze's truck with the lights. I don't think he will mind me posting them.
Tom
Thanks for the link for the clamp mount. I always wondered who made that.
ID:	37632   Click image for larger version
Old April 5th, 2011, 08:24 AM
kevkon's Avatar
kevkon
kevin
Hard to notice with those landing lights
Old April 5th, 2011, 10:39 PM
surf110's Avatar
surf110
Ze
130 Project
Nice 110!
Tom
ht, lights, vin
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
Driving lights out? Quimbola Defender Technical Discussions 3 January 26th, 2010 03:08 PM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
