Driving Lights - Defender Source
Old March 24th, 2010, 06:15 PM
bjf's Avatar
bjf
barry f
94 ST #395
Driving Lights
So I bought some lights for the front of my 90. I want to wire them so I can turn them on without anything else.
What do I need to do. I want the switch in the factory location on the left.
thanks
Old March 24th, 2010, 06:23 PM
phoenix37's Avatar
phoenix37
john
you can look at mine tomorrow.
Old March 24th, 2010, 06:52 PM
Rugbier's Avatar
Rugbier
Gustavo
Barry,
If you want them on without the Key, just run the wires from the switch to a relay to the battery.
If you want them to be activated only when the key is on, same procedure but the relay needs to be hot from an accessory line or fuse box place that get hot with the key
Not that complicated.
I always have my off road lights independent of any other lights
Now.. what lights did you get ? *LOL*
NO SIGNATURE
Old March 24th, 2010, 07:12 PM
bjf's Avatar
bjf
barry f
94 ST #395
What kind of relay? I need pics. Where to run wires etc.
thanks
Old March 24th, 2010, 07:17 PM
Rugbier's Avatar
Rugbier
Gustavo
Barry,
Everything you need to know ;-)
How to wire
http://www.rallylights.com/hella/Relays.aspx
The relay Kit
http://www.rallylights.com/detail.aspx?ID=3945
RN also sells the relay by itself
NO SIGNATURE
Old March 24th, 2010, 07:23 PM
bjf's Avatar
bjf
barry f
94 ST #395
cool thanks
Old March 24th, 2010, 07:34 PM
Rugbier's Avatar
Rugbier
Gustavo
no worries
if you are installing and get a hiccup let me know
NO SIGNATURE
Old March 25th, 2010, 12:40 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Did you buy the lights new or used? Most lights come with a relay with the wiring harness, but not all.
Which ones did you get?
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 25th, 2010, 01:01 PM
bjf's Avatar
bjf
barry f
94 ST #395
I bought gustavos
Old April 18th, 2010, 01:21 AM
bjf's Avatar
bjf
barry f
94 ST #395
So I have been setting up my lights and I have a question. I used a hella 4000 wiring kit. It has all the wires, relay, etc. I made some changes as I am using hella 1000 but the concepts are the same. My question is off the switch is one wire that goes to the relay and one that is supposed to go to the high beams. I want my lights wired so that I can turn them on whenver. Does that mean that this wire should go direct to the battery then?
http://www.rallylights.com/hella/AuxLampWiring.aspx - basic idea of what I am doing. I just assume the wire to the far right would connect to the battery (source of switched +12)
thoughts?
Old April 18th, 2010, 01:40 AM
terminal 86 in the diagram is used for the switch, if wired to your high beams they come on only when the high beams are active (driving lights in this example)
you want to run this to your switch and to continius pwr (i.e battery) for independant control or to switched pwr for ignition on control in your case.
this is the relay "trigger" terminal.
make sense?
95' D90 - daily driver..
Old April 18th, 2010, 01:50 AM
specops1526's Avatar
specops1526
Beluga '97 90
I'll be expecting you at my house to wire up mine after you figure it out.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old April 18th, 2010, 01:57 AM
bjf's Avatar
bjf
barry f
94 ST #395
make sense?
Thanks so as in the diagram I have two wires going to the positive on the battery. one from the switch and one from the relay?
I want mine to work independent of anything else.
ht, lights, vin
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
Driving lights out? Quimbola Defender Technical Discussions 3 January 26th, 2010 03:08 PM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
