Drivetrain question - Defender Source
Old May 25th, 2015, 12:17 PM
seanreaganphoto
Sean Reagan
1995 Defender 90
Drivetrain question
Hello - recently damaged u-joint and front prop shaft far from home. Removed front prop shaft hoping to proceed on highway using only the rear prop shaft but vehicle acted as if in neutral unless diff engaged. Should I have expected to be able to continue on with only one prop shaft in place? Do I have a problem somewhere in the drivetrain? Seems transfer case is not sending power to the rear in high range.
Any insight would be appreciated - down in Mexico without too many people to ask about Landys. Thank you.
Old May 25th, 2015, 12:30 PM
You need to lock the center diff to drive in rear wheel only mode.
Old May 25th, 2015, 12:52 PM
seanreaganphoto
Sean Reagan
1995 Defender 90
Thank you!
What's up with the Slop in the Drivetrain? spencer08291985 Defender Technical Discussions 75 June 17th, 2015 08:32 PM
Griding from drivetrain when i hit the clutch? oldscratchggf Defender Technical Discussions 6 November 29th, 2005 01:59 AM
1990 Range Rover w/37" MTR's and Toy Drivetrain lwg For Sale - Vehicles 0 October 17th, 2005 03:06 PM
109 rolling chassis, drivetrain bulkhead $500 evilfij For Sale - Vehicles 1 June 20th, 2004 07:50 PM
banging in drivetrain prospector Defender Technical Discussions 8 June 14th, 2004 11:17 PM
