driveshaft direction - Defender Source
Old November 1st, 2008, 04:17 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
So I have had both my driveshafts out to put new u-joints in them and now when I am putting them back in I want to make sure they are facing the proper direction. I can tell the front shaft from the rear shaft just by look but cannot discern between the front of the front shaft and the rear of the front shaft. Same for the rear shaft. Any easy way to tell?
B
Old November 1st, 2008, 04:41 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
The slip joint on the rear shaft of the 110 is near the t-case. Can't remember about the front shaft. If no one else chimes in, I'll go take a look later on.
-Neil
Old November 1st, 2008, 04:57 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
Just had a look under my 110 and my Series 3. Slip joints on the rear shaft are up near the transfer box and the slip joints on the front shaft are near the diff.
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old November 1st, 2008, 05:15 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Totally appreciate the help and the fact that you guys went out and looked..way beyond the call of duty. But...next stupid question. Slip joint? Is that the joint on the skinny end of the shaft or the fat end. I am gonna guess skinny?
B
Old November 1st, 2008, 05:34 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
It's the part that, well, slips. It usually has a zirc on it (grease nipple...heh heh, greased nipple), on the shaft, not in the u-joint. Ahhh, nipples, shafts, I hope JimC doesn't close this thread down.
Sorry, haven't seen the wife in a while. I chose to spend last weekend with a bunch of smelly old men (URE!).
Old November 1st, 2008, 05:43 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Gracias. Both shafts were in the correct position. Amazing because I have absolutely no luck, and clearly skill had nothing to do with.
Hope you see your wife...SOON!
B
Old November 1st, 2008, 08:26 PM
Exclamation
Who you calling old Gorbachev ?
Old November 1st, 2008, 08:40 PM
Hey now. Doug's old, but I'm not.
Back on topic, does it really matter? And why would the front be one way and the rear another? The only diffence I can think of would be water ingress and perhaps balance.
Old November 1st, 2008, 08:49 PM
Way to have my back Charles.
Keep the splines (they do wear out-ask me how I know) away from as much grime as possible.
I have both of mine with the slip joint up by the transfercase- additionally this lets the grease work its way down the splines.
Old November 1st, 2008, 09:49 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Everyone please take note how neither denied the smelly part.
Old November 1st, 2008, 09:52 PM
Neil, consider yourself warned
Old November 3rd, 2008, 10:30 AM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
I was more concerned with balance than anything. Took it out on a test run and appears to be running fine. Now just have to work on the 3,000 other things on the to do list.
B
drives
Driveshaft replacement Doug Defender Technical Discussions 39 July 9th, 2008 11:24 AM
Driveshaft Issues Continue...?? P1CR Defender Technical Discussions 9 July 22nd, 2004 09:12 PM
Air Conditioner Vents on NAS 110 - How to hold direction of flow? COSteve Defender Technical Discussions 5 July 15th, 2004 11:11 AM
Driveshaft weights? Help! P1CR Defender Technical Discussions 11 June 30th, 2004 02:16 PM
Stripped nuts on the driveshaft... dmarchand Defender Technical Discussions 13 November 18th, 2003 09:41 PM
