Driver's Side Vent Cover on 97 - Defender Source
Old June 10th, 2009, 06:02 PM
specops1526's Avatar
specops1526
Beluga '97 90
Just out of curiosity, why is the vent cover on the driver's side wing of a 97 sealed?
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old June 10th, 2009, 06:38 PM
GYM's Avatar
GYM
Gary
97 SW
Heater intake in a RHD truck goes there. (Then the other wing vent would be sealed.)
I replaced the the sealed vent grille with a vented one from George for a bit more air circulation.
Old June 10th, 2009, 07:01 PM
specops1526
Beluga '97 90
So if it were opened to the elements would it cause any issues? or is it just an opening to the engine bay? (don't have the truck with me or else I'd be able to look)
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old June 10th, 2009, 07:11 PM
GYM's Avatar
GYM
Gary
97 SW
Yes, it just opens to the engine bay, (top of the inner fender) and it would be exposed to the elements; but as the old song says, it never rains in So CA right?? :-)
Try removing it sometime and then drive up a long steep grade, (like the Grapevine). You'll see the heat waves venting out...
Old June 10th, 2009, 07:42 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Likely because the main fuse block is right next to the opening.
Email:
Old June 10th, 2009, 08:30 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
I had them both opened on my 95. When I was off-road my coil used to get wet all the time and the truck would die on the trail. I learned to carry around dielectric grease or WD40!
Old June 10th, 2009, 08:34 PM
GYM's Avatar
GYM
Gary
97 SW
Mike, in your opinion, is that significant?
Fuse box is under the bonnet, adjacent to (and level with) the wing vent opening, but not underneath or behind it.
Intuitively, based on location, it seems that the fuse box would be 'more at risk' to water splashing up from underneath the truck and rain ingress from the gap between the bonnet and wing than it would be from an open wing vent, no?
No coil issue on a 97...
97, cover
Drivers Side Wing Top Vent Troys Wanted 0 November 20th, 2006 09:40 PM
NAS drivers side fender steved90 Wanted 0 August 1st, 2005 04:52 PM
Need Ac Vent And Cover Seat Base Over Battery FREEDOM Wanted 2 May 29th, 2005 12:19 AM
WTB: Driver's Side Side Step dzientek Wanted 0 November 8th, 2004 12:21 PM
Wanted: D-90 seat back trim cover/ driver's side side step dzientek Wanted 2 August 23rd, 2004 06:39 PM
