driver/passenger door latch issues! - Defender Source
Old October 5th, 2011, 03:59 PM
97Ariesblu's Avatar
97Ariesblu
kyle scheppler
1997/D-90 Station Wagon
ok for some reason the doors will shut then open slightly (obviously not all the way) but its because the latch doesnt stay catched on the reciever...what could possibly be broken in that area (becaue its hard to get to first of all, because ive taken off the door panel and looked at the arm and everything is alright with that, nothing wrong with that it seems,
So, it seems the problem is only coming from the latch mechanism, which I cannot get into really with my eyes to see if something is broken or what...take a look at the pics, because playing with it, it seems fine but then it wont keep the door fully closed, like it doesnt lock in place (you hear the first part of the catch , then the second part of the catch wont stay closed, leading me to believe something is not keeping that latch where it is supposed to stay...any suggestions? ... im going to unscrew those 3 screws to get into the latch area, but im not sure what to look for...
any help/suggestion would be much appreciated
thx guys,
Ky
ID:	42515   Click image for larger version
I wonder if I can drive over that..?
Old October 5th, 2011, 04:56 PM
specops1526's Avatar
specops1526
Beluga '97 90
Have you tried spraying some WD-40 into it first? Maybe it's just a little gummed up? Is it just one or both door?
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old October 5th, 2011, 06:51 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
In my experience it is all about the door catch and the spacers that make all the difference not the door catch. I had the same problem when I switched to SW doors and it took much experimentation to get it right. What I do is loosen the hinges then close the door all the way and then re-tighten the hinges. Viola! works for me!
Todd
'95 D90 #2206
'66 109" P/U
Old October 6th, 2011, 03:22 AM
97Ariesblu's Avatar
97Ariesblu
kyle scheppler
yes its both doors but drivers side is wyyy worse.....
ill try working with the catch too becasue i cannot find anthing wrong other than it wont STAY latched all the way...the primary latch wont stay shut, but the secondary one always catches so the door doesnt just swing open, you still have to press the door button to completely release door from latch from catch...
Old October 8th, 2011, 04:38 AM
97Ariesblu's Avatar
97Ariesblu
kyle scheppler
ok so im still having the same problem...when i shut the door i feel the first part of the latch catch...then when i push harder the second part of the latch also catches, BUT then the problem comes in...as soon as i release my hand pressure the second part of the latch wont hold, it just pushes back the door slightly open, but not past the first part of he latch catch (so the door stays closed, just not fully closed)... i think im going to play around with the catch some more, but that part seemed ok, but i just cant figure out what the problem is
Old October 8th, 2011, 04:02 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
its most often the catch not the lock, on some models the catch has an anti rattle plastic sleeve over the bar that the Y piece in the lock hooks around, check to see if the anti rattle sleeve has worn through to the centre bar.
try adjusting the position of the catch to allow the lock to close correctly, also if the hinges are very worn it can cause the same effect.
Oh and so does fitting new door seals...!
regards
Gren
door, door latch
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Server issues chrisvonc Support & Suggestions 4 June 16th, 2005 01:17 PM
EMERGENCY-Xfer case issues Cyborg Defender Technical Discussions 7 July 18th, 2004 02:50 AM
Getting Help, Outstanding, & Known Issues chrisvonc Support & Suggestions 0 May 23rd, 2004 06:00 PM
