Driveline Vibration - Page 2 - Defender Source
Old March 31st, 2006, 09:27 PM
johare
Jay
95 D90 White ST
I think its FIXED! I reinstalled the rear driveshaft rotated 180 degrees and the vibration is almost completely gone. I mean 100% better! Since this is my first D90 and its vibrated since day 1 I'm not sure what the optimum experience should be. Here is the theory of what happened:
We replaced the u-joints first as a possible fix but more as a maintence measure as this is a new vehicle. At the same time, the front left wheel bearing was in desperate need of an adjustment/repack as there was significant play . We think that during the u-joint replacement, which we did first, the shaft was mistakenly reinstalled 180 degrees off. So at one pont we had the wheel bearing AND the rear shaft causing vibration. When the wheel bearing was fixed we did not think to consider the rear shaft because we assumed the u-joint/install was correct. So the wheel bearing gets adjusted but the rear shaft was off.
This was a great learning experinece for me and a lot of really good posts on this thread to help other folks troubleshoot the driveline.
Jay
Driveline Vibration Issue - Possible Root Cause (some people are crazy...) pmd Misc. Chit-Chat 2 January 16th, 2009 09:23 AM
Vibration while coasting kellymoe Defender Technical Discussions 12 September 24th, 2005 05:09 PM
driveline locks up stevewhitaker Defender Technical Discussions 14 February 26th, 2005 03:14 PM
vibration question stevewhitaker Defender Technical Discussions 10 January 18th, 2005 04:25 PM
Drive Line Vibration reggie Defender Technical Discussions 4 May 13th, 2004 12:27 AM
