Driveline slop - Defender Source
Old June 22nd, 2011, 08:06 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Driveline slop
I'm experiencing major slop in my driveline; it's most noticable when the truck is in gear and I let off the accelerator or get back on the accelerator while coasting. I also feel it when clutching out while shifting. The truck jerks pretty hard when it happens.
I started yanking on things last week and found a failing u-joint in the Tom Woods shaft. I replaced this and had it re-balanced but the slop persists.
Earlier this spring, I sheared an axle tube and had it rewelded so I could limp back home. I swapped the diff and axles to a new housing and installed them. Shortly after this, I started noticing the slop.
I suspect the Detroit locker in the rear. Has anybody experienced this problem with a Detroit?
Old June 22nd, 2011, 09:20 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Maybe I am misreading the jerky part but it sounds more like you are suffering from rear steer...this is more likely bushings than driveline. I had this same thing in my truck (truck would pull pretty hard if I let off the throttle at highway speed) and with new bushings and properly torquing the nuts on the trailing arms I have had zero problems
Posted from my BlackBerry using BerryBlab
Old June 22nd, 2011, 11:15 PM
chris snell
Chris Snell
87 Ex-MOD 110
It's steering just fine. The sensation that I get is the same that you'd get if you let off the clutch too quickly. For what it's worth, clutch was replaced about 3,000 miles ago.
Old June 23rd, 2011, 09:36 AM
TS888's Avatar
TS888
Tony Sims
1984 110
How's your A-arm ball joint in the rear? It certainly could be drivetrain, but a loose ball joint can allow a lot of motion when transitioning power on/off.
Tony
1984 110 "Smokey" (sold)
Old June 23rd, 2011, 09:57 AM
reb78
REB
Land Rover 110
Thatd be my first stop also. Replacing the ball joint often removes a lot of the clunks you can hear!
Old June 23rd, 2011, 10:54 AM
Are you completely sure that it's not your engine experiencing fueling/timing issues as the throttle slams shut? Usually this sort of thing is somewhat violent (lurching forward and lurching to a stop.) I find it difficult to believe that driveline slop would contribute to this behavior at any speed above a few miles per hour, although it's possible if it was perhaps located in the transfer case or transmission before the substantial gear reduction by the time power hits the center differential...
Old June 23rd, 2011, 11:37 PM
chris snell
Chris Snell
87 Ex-MOD 110
It's definitely not a problem with the motor, which is tip-top. It's not the a-arm, either. I replaced the ball joint last September and I checked it tonight and the castle nut is properly tightened.
I'm thinking more and more that it's the Detroit based on the location of the noise when the power transfers.
Old June 24th, 2011, 08:45 AM
exmod110's Avatar
exmod110
Don Lang
Check all of ur drive flanges for wear....
85 exmod 110 rhd 300tdi
Old June 26th, 2011, 02:44 PM
TS888's Avatar
TS888
Tony Sims
1984 110
Also good advice. One of the flanges on the back of my 110 was so worn it had barely 1mm of material lrft actually driving, and a lot of slop. The half shaft had taken a beating too, had to be replaced.
Tony
Driveline noise steinhnj Defender Technical Discussions 3 July 30th, 2007 01:38 PM
Driveline Vibration johare Defender Technical Discussions 20 March 31st, 2006 09:27 PM
driveline locks up stevewhitaker Defender Technical Discussions 14 February 26th, 2005 03:14 PM
Driveline (shaft) problems continue... P1CR Defender Technical Discussions 2 July 16th, 2004 10:39 AM
Driveline Clunk in early '94 D90 Hans Defender Technical Discussions 8 November 25th, 2003 09:43 PM
