driveline locks up - Defender Source
Old February 17th, 2005, 11:34 PM
stevewhitaker's Avatar
stevewhitaker
Stephen Whitaker
1994 D-90
driveline locks up
Twice now my 1994 D-90 driveline has locked up after being parked for a couple of days. First time I thought it was due to ice on brakes. Second time it was 65 degrees out, so now I fear something more major. When first engaging the clutch the drive line torques up but the car won't budge; then the driveline lets out a loud BANG (can't tell from where) and I can move again. I bought this truck 3 months ago from a dealer (American Fork, Utah) who told me he had just installed a new (not rebuilt) tranny 1000 miles before I took possession. I pulled axles and diffs but could see not problems. I hear no peculiar noises from the driveline while driving. Has anyone got a clue regarding the cause of this problem??
Old February 17th, 2005, 11:57 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Transfer case spider gears?
JP
legend in my own mind
Old February 18th, 2005, 01:06 AM
headdamage's Avatar
headdamage
Andrew
exmod 90 2.5na and a 93/RRC 200tdi
Oil on the brake discs?
Old February 18th, 2005, 06:44 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I would check the e- brake linkage too
Legend in My Own Mind.
Old February 18th, 2005, 07:55 AM
Next time it happens put the T-case in Neutral and let the clutch out, this will rule out the trans and the input to the T-case. If not then jack up one front tire and crawl under the truck and try turning the front driveshaft, it should spin freely and this will rule out the front Diff and the front output of the T-case. Then do the same in the rear but release the park break, and try and spin the rear driveshaft, this should also spin freely and rules out the rear diff and the rear output of the t-case. I know these things happen when you're going to work or something but it's the best way to find it with the least amount of work.
Old February 18th, 2005, 12:03 PM
stevewhitaker
Stephen Whitaker
1994 D-90
Thanks for the replies. Brakes are oil free. I have not checked T-case spiders. Mike, I shall perform the tests you indicate in the hopes that I can isolate the trouble. At the moment I have dropped the plate in the T-case and have also removed the gears from the input shaft, but can see nothing in the way of broken parts, so at least I am not clanging apart the gears there. I am a bit new the the Defender's set-up having owned and worked on a Series IIA for three decades. I never had this problem before. It acts as though it is in two gears at once or something. Strange... I sure don't want to experience what happens if things jam while I'm on the highway.
Old February 18th, 2005, 12:20 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I had that happen to me once too, it ended up being in the parking brake drum. Easy to diagnose in my case because after it let loose, the parking brake stopped working totally. Dealership fixed it in that case so I don't know exactly what to look for, but no parts were required.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 18th, 2005, 08:29 PM
Selll it to me.
Ron
Old February 18th, 2005, 11:30 PM
stevewhitaker
Stephen Whitaker
1994 D-90
Thanks Hans. I'll check the brake drum too. Hey Ron, I have a few more "Rover moments" to live through before I get fed up enough to sell.
Old February 19th, 2005, 06:10 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I'm sure it will be the transmission brake. next time it happens before forcing it free with engine torque stop the engine put it in gear and with the transmission brake released give the back plate a bosh with a hammer. It's probably the release mechanism full of much and then it rusts uo jamming the transmission brake. It needs a disassemble, clean and lubricate. My 90 does exactly th same thing if left standing for a while.
Mike Hammond
Old February 21st, 2005, 01:20 PM
stevewhitaker
Stephen Whitaker
1994 D-90
Thanks Mike, I shall get to that tranny brake ASAP. And while I am at it, my checking of things has uncovered the fact that my rear brakes on not working at all, so I reckon I may get to play with a new master cylinder in the coming days. Ahhhh, the joys of getting a used truck...
Old February 21st, 2005, 01:46 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Steve, try to rebuild your master. It is very easy & you can get the parts from RDS cheap!
Old February 25th, 2005, 02:46 AM
mikeslandrover
Mike Hammond
Are you sure it's the master cylinder?
Check tthe rear calipers (I'm assuming that you've got disc brakes at the rear) the pistons might well be seized in the calipers. It's not an uncommon problem, I tend to move the pistons right back into the calipers when I give my truck a thorough clean after muddy off roading.
The other possibility is a collapsed flexible brake pipe to the back axle.
Then of course theres the brake ballance valve, goodness knows what goes on in there
I'd tear apart the master cylinder last of all.
Mike Hammond
Old February 26th, 2005, 12:03 PM
stevewhitaker
Stephen Whitaker
1994 D-90
Yeah, the master cylinder is the just about the last step in my routine. The pistons work fine and the calipers seem okay; no brake line problems. I am with you about the mysterious workings of the brake balance valve, which could be the culprit. Oh well, what else would I be doing in my spare time anyway... beside yardwork, fixing things around the house, cleaning out the garage, etc, etc, etc.
Old February 26th, 2005, 03:14 PM
mikeslandrover
Mike Hammond
Ah but fixing Land Rovers is soooo much more rewarding. especially if the heavens open when you're half way through a job , and then there's the cold (well it's cold over here at the monent)
Mike Hammond
Power Locks in a ST? mod4b Defender Technical Discussions 9 June 17th, 2005 02:32 PM
Winch Bolt/Nut locks - like wheel(lug nut) locks Jase Defender Technical Discussions 4 February 20th, 2005 08:31 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Soft-top doorhandle locks proulx70 Defender Technical Discussions 19 October 16th, 2004 12:14 PM
Driveline (shaft) problems continue... P1CR Defender Technical Discussions 2 July 16th, 2004 10:39 AM
